Question about Samsung SCH-u740 Cellular Phone
My phone won't find my plantronics 22o headset
    Brigadier General:
  • 7,752 Answers
Make sure both are switch on , make sure the phone BT is visible also then try pairing once more if that still does not work delete all paired devices to your phone then try again if the problem is still there then take both to the store and have a tech assist you further.
Posted on Sep 20, 2008
My 220 will no longer power on. It shows the red light when connected to the charger but unplugged won't come on
That Plantronics Explorer 220 headset is an older model, it may just be worn out. The Plantronics M20 would be a good replacement to look at, here is the link:
Plantronics Explorer M20 Headset
Good luck from Headsets Direct!
Oct 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
Plantronics discovery 975 won't turn off nor pair with phone...
Just to make sure you are turning off the earpiece correctly:
Press the call control button for 4 seconds. It will glows red. Then you will hear 4 descending tones. If this does not work I would suggest taking it back to where you purchased it from and have it replaced, the headset has a one year warranty.
Good luck from Headsets Direct - 800-914-7996.
Aug 05, 2011 | Plantronics Discovery 975 (8164001 P)...
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
How I can listen music through headset
Your Plantronics Voyager Pro Plus is equipped with A2DP which makes the streaming of music in the headset possible. However if the phone you have does not have that application it won't happen.
May 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics 220 won't turn off. The blue light won't turn off and I can't get it on or off.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Here is the link for the Plantronics 220 User's Guide.
May 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Just need a printable manual
here is the pdf of it.
http://www.greennet.ca/ebay/Explorer220_PLN-7551601/explorer220_datasheet_en.pdf
if it doesn't work try going here.
http://phone.manualsonline.com/manuals/mfg/plantronics/220.html
Then click on "get this manual" and when a window pops up click "skip special offers"
Jul 02, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 330 bluetooth headset / Nextel Blackberry 7100i performance
After looking through the phones, there many possibilities, wow quite a few. It does not have any recommendations on headsets. The headset is only as good as the the quality you are purchasing. If your phone drops calls it won't be from the bluetooth device. Below is a link to the Explorer Series 300 User's Guide, which may help you.
Plantronics Explorer Series 300 User's Guide
Sep 22, 2008 | Plantronics Explorer 330 Headset
Samsung SCH-u740 Cellular Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
