Question about Radio Shack Accurian APD-3955
Won't read dvd!
It plays music,but not play dvds! I have cleaned the player and unpluged it and still no dvd
  • Anonymous Nov 17, 2008
    its not reading cd to play movies but music does play
Open it and clean it from the inside with a air brush. Clean the lens, the battery, the motherboard, well just air brush the parts you can. CAREFULLY though. If you rip anything the DVD player is gone. Most of the time dust collects inside and a air brush can't get to though place of the lens from the outside. Hope This Help.
-Himel
Posted on Jul 22, 2008
My Dynex DVD TV plays some DVDs and on other ones will spin like it is reading then stop and read, no Disc. I have cleaned the lens several times, but still will not play certain DVDs that it use to...
Hi, Did you also clean the disc's of dirt and finger prints. There are some discs that you will not be able to play. Ones that were made on certain computers.(format) In the manual it will list all dvd's you can play. even music CD's Good luck.
Feb 21, 2015 | Dynex Televison & Video
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
Samsung htz310 reads NO DISC
probebly a bad laser. sometimes they will play music but not dvds or even the other way around. from what iv read this is happening to people in just a few weeks.
Nov 19, 2011 | Televison & Video
I cant get my dvd player to play my dvds or my music cds
I'm having the same ****... 10th time with the P.O.S.!!!
I found another posting... I've tried so many things, but this helped... for now anyway!!
Take a "Q tip" and clean the DVD lazer eye with a small amount of rubbing alcohol. That did the trick for me... again, at least or now..
Hope it works.
jc
Apr 11, 2009 | Acer Aspire 6920 Notebook PC
Quit playing D VDs
it sounds like bad connection dry joint , needs service clean if you are here in brisbane
i could fix ?
if you can service yourself ok, but if not you can
call 0403960527 jeff.....
Feb 16, 2009 | JVC XV-FA95 Multi-disc DVD Player
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
CH dvd300 plays music cds wont read dvds states continuously insert disc
The non-technical answer would be that the lens needs to be cleaned. This is the first step for this type of problem. There are many things that can get the disk drive lens dirty like smoke, incense, dust, moisture. Open the unit and open the DVD cover. You will see the lens that reads a DVD. Get a cotton swab (the ones for cleaning out ears) and some isopropyl alcohol (rubbing alcohol) and moisten the cotton swab with the alcohol (moisten not soak) and gently (I mean, do not push hard or scrub hard) rub it on the lens. Now with a dry cotton swab, do the same. Let it dry for a minute (longer if the swab had more alcohol and it might have dripped down) and close the unit. Now try to play DVDs and let us know if it worked. If this does not do the trick then it could be a firmware issue that can only be fixed if the company put a download on their support page.
May 29, 2008 | Cyberhome CH-DVD 300 DVD Player
Mintek
The part that reads the DVDs is defective. I would suggest to try cleaning it using a lens cleaner, hopefully that works.
If the cleaning does not work, it might just be cheaper to buy a new one instead of repairing this one.
May 20, 2008 | Mintek MDP-1760 Portable DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Radio Shack Accurian APD-3955 Logo
80 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
