Question about Microsoft Windows XP Professional
Password disabling in windows xp
Disable the windows xp administrator password or any user password
  • 1,498 Answers
To do this, you must be logged in as a user with administrative privileges
Click Start. Click Control Panel. Click User Accounts.
The existing accounts will be displayed.
Click the one you want to change.
A screen will ask what you want to change along with several options.
Click on 'Remove Password'.
After assuring the Windows that you're sure, a delete password button will appear. Click it.
No more password.
If you found this helpful, please take a sec and rate this response.
Good luck
Mike
Posted on Jul 17, 2008
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
Aug 04, 2013 | Computers & Internet
Tip
Enable / Disable the Local (Hidden) Administrator Account in Windows 7
Ways to Enable / Disable the Built-In Windows 7 Admin Account Many people familiar with prior versions of Windows are curious what happened to the Local Administrator account that was always created by default. Does this account still exist, and how can you access it?<br /> Recently I ran into an awkward situation where after disjoining a Windows 7 client machine from the domain, I was unable to log in to the computer. This was not because I had forgotten the local administrator password, but because the local administrator account was disabled (which is the default behavior in Windows 7). Like in Windows Vista, in Windows 7 the built-in Administrator's account is disabled by default. Furthermore, this account is not associated with any password. After doing some research, I found the following procedure that worked really well.<br /> <a href="http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm">Enable Built-in Administrator Account</a><br /> Basically there are 4 ways in order to activate the account:<br /> A) Command Prompt To enable the built-in Administrator's account by using the Command Prompt please follow these steps:<br /> 1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator" (or use the Ctrl+Shift+Enter shortcut from the search box)<br /> <img src="run-command-prompt-as-administrator.jpg" /> 2. After that you only need to enter the simple command below to activate it.<br /> <b><i>net user administrator /active:yes</i></b><br /> <img src="enable-hidden-administrator-account.png" /> 3. You should see a message that the command completed successfully. Log out, and you'll now see the Administrator account as a choice.<br /> <img src="built-in-windows-7-administrator-account.png" /> You'll note that there's no password for this account, so if you want to leave it enabled you should change the password.<br /> B) Local Security Policy Another way of activating the administrator account in Windows 7 is via Local Security Policy.<br /> 1. Type secpol.msc in the search bar and hit enter.<br /> <img src="secpol.png" /> 2. After the Local Security Policy pops up, navigate to Local Policies-&gt; Security Options where you can see an entry that reads Accounts: Administrator account. Double click the entry to enable it.<br /> <img src="local-security-policy.png" /><br /> <img src="administrator-account-status.png" /> C) Using the Local Users and Groups Snap-in To enable the built-in Administrator's account by using the Local Users and Groups snap-in please follow these steps:<br /> 1. Open Local Users and Groups. You can do so by typing lusrmgr.msc in the Start search box or in the Run command and pressing ENTER. Or, you could open Computer Management by right-clicking Computer in the Start menu and selecting Manage.<br /> 2. Expand System Tools &gt; Local Users and Groups &gt; Users.<br /> 3. Right-click the Administrator account and select "Set Password".<br /> 4. In the"Set Password for Administrator" click "Proceed".<br /> 5. In the"Set Password for Administrator" enter the Administrator's desired password twice, and click "Ok".<br /> 6. Next, enable the Administrator's account. Right-click the Administrator's account and select "Properties".<br /> 7. Un-chek the "Account is disabled" check-box. Click on the "Ok" button.<br /> Administrator's account is now enabled and configured with a password.<br /> D) During the Installation Process There is a 3rd method which advanced users can use. This method can be used during the installation process itself.<br /> 1. During the installation, after being prompted to configure the new user account, you will be able to set the new account's password.<br /> 2. At that phase, press SHIFT and F10 keys together. A Command Prompt window will appear.<br /> 3. In the Command Prompt window, type:<br /> <b><i>net user</i></b><br /> Note how the Administrator account is there, yet the new user account has not been yet created.<br /> 4. To set the Administrator's account password:<br /> <b><i>net user *</i></b><br /> 5. Then enter the required password and confirm it.<br /> 6. To enable the Administrator's accoun:<br /> <b><i>net user administrator /active:yes</i></b><br /> 7. Close the Command Prompt window and continue with the installation process.<br /> If you log off you will now see the Administrator's account as a valid logon option.<br /> Disable Built-in Administrator Account Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:<br /> <b><i>net user administrator /active:no</i></b><br /> <img src="disable-local-admin-account.png" /> The administrator account will now be disabled, and shouldn't show up on the login screen anymore.<br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Hack into Windows 7 Administrator Account </a> [Free Trial] Article source: http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm<br />
on May 23, 2011 | Computers & Internet
Tip
Enable / Disable the Local (Hidden, Built-In) Administrator Account in Windows 7
Ways to Enable / Disable the Built-In Windows 7 Admin Account Many people familiar with prior versions of Windows are curious what happened to the Local Administrator account that was always created by default. Does this account still exist, and how can you access it?<br /> Recently I ran into an awkward situation where after disjoining a Windows 7 client machine from the domain, I was unable to log in to the computer. This was not because I had forgotten the local administrator password, but because the local administrator account was disabled (which is the default behavior in Windows 7). Like in Windows Vista, in Windows 7 the built-in Administrator's account is disabled by default. Furthermore, this account is not associated with any password. After doing some research, I found the following procedure that worked really well.<br /> <a href="http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm">Enable Built-in Administrator Account</a> Basically there are 4 ways in order to activate the account:<br /> A) Command Prompt To enable the built-in Administrator's account by using the Command Prompt please follow these steps:<br /> 1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator" (or use the Ctrl+Shift+Enter shortcut from the search box)<br /><img src="run-command-prompt-as-administrator.jpg" /> 2. After that you only need to enter the simple command below to activate it.<br /> <b><i>net user administrator /active:yes</i></b> <br /><img src="enable-hidden-administrator-account.png" /> 3. You should see a message that the command completed successfully. Log out, and you'll now see the Administrator account as a choice.<br /><img src="built-in-windows-7-administrator-account.png" /> You'll note that there's no password for this account, so if you want to leave it enabled you should change the password.<br /> B) Local Security Policy Another way of activating the administrator account in Windows 7 is via Local Security Policy. <br /> 1. Type secpol.msc in the search bar and hit enter. <br /><img src="secpol.png" /> 2. After the Local Security Policy pops up, navigate to Local Policies-&gt; Security Options where you can see an entry that reads Accounts: Administrator account. Double click the entry to enable it.<br /><img src="local-security-policy.png" /><br /><img src="administrator-account-status.png" /> C) Using the Local Users and Groups Snap-in To enable the built-in Administrator's account by using the Local Users and Groups snap-in please follow these steps:<br /> 1. Open Local Users and Groups. You can do so by typing lusrmgr.msc in the Start search box or in the Run command and pressing ENTER. Or, you could open Computer Management by right-clicking Computer in the Start menu and selecting Manage.<br /> 2. Expand System Tools &gt; Local Users and Groups &gt; Users.<br /> 3. Right-click the Administrator account and select "Set Password".<br /> 4. In the"Set Password for Administrator" click "Proceed".<br /> 5. In the"Set Password for Administrator" enter the Administrator's desired password twice, and click "Ok".<br /> 6. Next, enable the Administrator's account. Right-click the Administrator's account and select "Properties".<br /> 7. Un-chek the "Account is disabled" check-box. Click on the "Ok" button.<br /> Administrator's account is now enabled and configured with a password.<br /> D) During the Installation Process There is a 3rd method which advanced users can use. This method can be used during the installation process itself.<br /> 1. During the installation, after being prompted to configure the new user account, you will be able to set the new account's password.<br /> 2. At that phase, press SHIFT and F10 keys together. A Command Prompt window will appear.<br /> 3. In the Command Prompt window, type:<br /> <b><i>net user</i></b><br /> Note how the Administrator account is there, yet the new user account has not been yet created.<br /> 4. To set the Administrator's account password:<br /> <b><i>net user *</i></b><br /> 5. Then enter the required password and confirm it.<br /> 6. To enable the Administrator's accoun:<br /> <b><i>net user administrator /active:yes</i></b><br /> 7. Close the Command Prompt window and continue with the installation process.<br /> If you log off you will now see the Administrator's account as a valid logon option.<br /> Disable Built-in Administrator Account Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:<br /> <b><i>net user administrator /active:no</i></b><br /><img src="disable-local-admin-account.png" /> The administrator account will now be disabled, and shouldn&iexcl;&macr;t show up on the login screen anymore.<br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Hack into Windows 7 Administrator Account </a> [Free Trial]
on May 03, 2011 | Computers & Internet
I forgot my administrator password for windows xp on an emachines computer
Follow the below steps to enable Windows XP built-in administrator account:
  1. Log on with the guest account on XP, then right click computer, and choose Management.
  2. Expand Local Users and Groups and Users in the console.
  3. Right-click Administrator account and select Properties.
  4. On the General tab, clear the Account is Disabled check box.
  5. Close the console.
    Now the super administrator account is successfully enabled. Next, you can easily reset the forgotten XP password from "Start->Control Panel".
If the above method can not help you, you can use Smartkey Windows Password Recovery to help you to reset windows xp administrator password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Sep 14, 2012 | E-Machines eMachines Desktop PC
How do u remove the password from windows xp computer log in screen
If the administrator has not been passworded or disabled, you can type in administrator for the user and no password. You can then open control pannel and remove the password off of the old user account. You may need to boot into safe mode to enter the administrator user account. Safe is entered by pressing the F8 key after the computer posts, and prior to windows loading.
Jan 26, 2012 | Dell Computers & Internet
Tip
How to enable Windows 7 administrator account and reset lost Win 7 admin...
How to enable Windows 7 administrator account and reset lost Win 7 admin password
There are two parts for your Windows 7:
* Enable Windows 7 administrator account
* Reset lost Win 7 admin password
With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods.
Part I: Enable Windows 7 administrator account
Method 1: Use Command Prompt
The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt.
1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator.
2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear.
3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled.
4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account.
Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps:
1. Switch to log on Windows 7 with the administrator account.
2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account.
3. Click Create a password for your account on the screen.
4. In the coming screen, type and confirm your Win 7 admin password.
5. Enter password hint and click Create Password.
Now your Windows 7 admin password is successfully created.
Method 2: Use Local Users and Groups
1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up.
2. Double-click the Users folder. And all the Windows 7 account will be displayed for you.
3. Right-click the Administrator account and select Properties.
4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen.
Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below:
1. Right-click the Administrator account and select Set Password.
2. Click Proceed to go on your operation
3. Type and confirm your new Win 7 admin password and click Ok
4. Close the Local Users and Groups screen.
Now the Windows 7 administrator password is assigned to your Windows 7 admin account.
Part II: Reset lost Win 7 admin password
Windows 7 administrator password reset Tips:
Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows.
Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password.
step 1. Download and install Windows Password Breaker.
step 2. Run the program and burn a Windows password reset disk.
Step 3. Reset Windows 7 administrator password with the disk.
It is an easy and safe way for Windows 7 admin password reset.
on Nov 02, 2010 | Computers & Internet
In the user accounts, it says i'm the administrator, under my name, well last night i was messing with shortcut and htkys, and it opened up a whole new desktop, and it said administrator on the start
Hello Sealiena Cox! How you doin.. well, what i wanna you to do is on the logon screen, do not click on any of those two accounts ok, now press Ctrl+Alt by keepin holdin 'em hit the Delete key twice, you will get another screen, type in user name Administrator, password ummm i dunno about it do have a password on your previous usage if yes then type it otherwise just leave the password blank. once you are in, and found that all files on your old desktop, do this: right-click on My Computer icon that on desktop -> select Manage > left pane navigate to Local users > Users, I need u here to disable any accounts u don't want to use except for the administrator account, to do so Right-click on the user name > select properties then tick that box saying " Account is disabled " > apply > ok and do so for the rest of accounts. DO NOT disable all accounts otherwise you will not able to access your Windows any more. that's not that dangerous but that time you need a computer technician to fix it for you, because it could not be fixed online. Let me know if that helped you in returning back your old desktop. if not then follow up. Thanks
gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Nov 05, 2011 | Microsoft Windows XP Professional
Forgot password for my laptop compaq armada 1750 notebook. I treid going in threw safe mode but it still asked for password. I tried going in as guest but it said account has been disabled.PLEASE...
You can't enter the laptop until it has Guest Account Enabled. It is surely disabled. And for that Forgotten Password, try to remember that do you have any other user on that laptop. If yes, then log into on behalf of that user and change the password of yours by accessing the User Account Page in the Control Panel. This way you need not have to remember the Password of that account. And if you don't have any other administrator, then try a Hard Reset. You can do it by De-attaching every internal and external Attachable part of the Laptop.
Thank you Sir, Have a nice day.
Sep 25, 2009 | Compaq Armada 1750 Notebook
How to disable Cd drive windows xp in a local user
you can disable the CD drive and USB in the BIOS or go to
regedit:
Hkey_Local_machine\system\CurrentControlSet\dervices\cdrom\start
1=eable, 0=disable
hkey_local_machine\system\CurrentControlSet\devices\usbstor\start
3=enable, 4=disable
Mar 09, 2009 | Microsoft Windows XP Professional
Windows XP Passwords
Well, the best way to setup security is through a BIOS password. This bypasses any operating sytem and doesn't allow any user interaction until the password is entered. Also, a user cannot edit anything in the BIOS without a master password.
Most BIOS systems can be entered by pressing delete during the initial startup of the machine.
As for windows XP, the only true security it has is the startup password. Which is setup through the users menu in control panel. You can, however, setup advanced security and disable many abilities of other users using the Administrator account on your operating system.
Sep 21, 2008 | Acer Aspire 5610-4648 Notebook
Microsoft Windows XP Professional Logo
93 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
