Question about Olympus Cameras
When I turn on my Camera, the screen turns blue and say Zoom Error in red writting, and it wont turn on, and the shutter will not shut!
  • 188 Answers
This happens du to friction in the movement of the lense assembly. Did you happen to drop it in sand or on hard surface. If the camera if exposed to sand, just the cleaning of the lense assembly,( gears and the barrels) will solve the problem. But, if any damage is there then the complete lense unit needs replacement.
Posted on Jul 17, 2008
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
I have a zoom error alert on the screen of my fuji j37 digital camera. When i turn the camera on the lens comes out and retracts straight away.
I had this problem for the first time yesterday, on my fifth use of the camera from new. The user manual says to turn it on and off a few times which I did but to no avail. I found advice on a different forum that said to hold your finger over the shutter as you turn it on, so that the lens doesn't have time to retract again. Sort of use your finger nail to hold the shutter up while the lens extends. Tried this and it worked, switched it off and back on agiain and it seems to be going fine now.
May 16, 2010 | Cameras
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Zoom error
If you are still under MFG warranty and bought it from Best Buy they will ship it to service most likely, If you have their service plan they will be able to ship it for service... this needs to be serviced by a professional repair place...
May 13, 2008 | Fuji FinePix A500 Digital Camera
Powers up and then shuts off
This should work for the A520. With NEW or freshly recharged batteries, remove the camera's memory card, then turn on the camera. You'll probably see an E30 error. Next turn off the camera. Next insert the memory card, and turn on the camera.
If the above doesn't work, the following blog outlines some other repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2007 | Canon PowerShot A520 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Lens problem
If you've replaced the batteries with fresh ones, it probably has a broken zoom assembly. It'll have to be replaced by a repair shop.
Dec 13, 2006 | Canon PowerShot A520 Digital Camera
Cameras Logo
63 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
