Question about Cameras
Green mode How do i turn it off?
Press the little green button on the bottom right (also has the little 'delete/garbage can icon above it). Then press 'mode' button. That's it! Then just choose the mode that you want.
Posted on Sep 13, 2008
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
Turn green mode off my camera
just hit the green button, its the delete pic button as well, but it can be used to turn green mode on and off.
Oct 24, 2012 | Pentax Optio E50 Digital Camera
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    When I turn on the camera, it says "green mode" then immediately turns itself off
    Green mode locks all the camera's settings except for the flash. It can be turned off, however. There are 12 preset shooting modes. The main menu screen features chirpy cartoon icons for all the standard options, and some more unusual selections. A MySpace-friendly self-portrait mode is included, as well as settings for snapping pets and food. Oddly, the menu is laid out in no particular order: the top row features program, night, movie, voice recording and novelty frames, while the more useful portrait and sport are relegated to the lower tiers. The pre-loaded frames are even lamer than we've come to expect from such fripperies, and they ratchet the processing time right up.
    Green Button - Define function of the GREEN button
    May 13, 2010 | Pentax Optio M20 Digital Camera
    Pentax Optio M20 in Green Mode switches off after turning on
    Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
    Jul 27, 2009 | Pentax Optio M20 Digital Camera
    Stuck on green mode cannot turn off
    There is a small green button on the bottom right of the back of the camera. The trash can points to it.
    Press that button. You will not delete anything and it will be taken out of green mode.
    Apr 21, 2008 | Pentax Cameras
    Green mode
    Press the trash can button which is also a green dot and it should reset.
    Dec 04, 2007 | Cameras
    Code locking of siemens mobile phone
    Siemens Mobile Secret Codes:
    C25:
    SP unlock *#0003*(secret code 8 digits)#
    *#0606# shows you Secret Code, but only without SIM Card.
    *#06# for checking the IMEI (International Mobile Equipment Identity)
    How to change PIN:
    **04*old PIN*new PIN*new PIN#
    How to check simlock status
    *#0606# and then press left soft-key, you will see strange characters, then text ("brak blokad"). If you see for example 260-02, it means the phone is locked to Era GSM. In older models you can use *#06# and see the same information after clicking on left key (you will see IMEI and software version).
    S4:
    Monitor Mode - how to activate:
    Press left soft-key, then 9 (SET UP) 8 (Phone Status). You will see IMEI number, then press left soft-key and in order 7684666 and red phone at the end (monitor mode has been activated). To read information from Monitor Mode - press left soft-key, then 5 (GSM SERVICE) and 6 (Monitor). Monitor mode turns off when you switch off the phone. You must activate it again if you want.
    How to see date of software:
    Press left soft-key, then 9 (SET UP) 8 (Phone status). You will see IMEI number, then press twice left soft-key, 98, left soft-key, 7684666, red phone (activates Monitor Mode), left soft-key, 56 (turns on Monitor Mode), left soft-key, 98, left soft-key, 7684666, hang up (red phone) >abck to "normal" and then left soft-key, 56.
    S6, S8:
    If you add to phonebook under 'own phone number' +12022243121 with namez (for example MMI), then you will see something smile.gif
    S10, E10:
    In phonebook enter +12022243121 as your own phone no. You will see a picture with sun, two palms and greetings.
    S15e:
    Monitor Mode:
    Code: *#7436267*8378# (*#SIEMENS*TEST#)
    Hold red phone button until it code disapears.
    Menu 3.3.4 Choose frequency.
    Menu 3.3.4.1 Automaticaly.
    Menu 3.3.4.2 Choose GSM-900
    Menu 3.3.4.3 Choose GSM-1800
    Menu 10.1 MS info
    Menu 10.2 Soft date
    Menu 10.2.1 Software version.
    Menu 10.2.2 EEProm version.
    Menu 10.3 Tst and product info.
    Menu 10.3.1 Handware data.
    Menu 10.3.2 Date of manufacture
    Menu 10.3.3 Service date
    Menu 10.3.4 Date of repair.
    S25:
    Enhanced Full Rate
    *#3370# turns on
    #3370# turns off
    Haft Rate Mode
    *#4720# turns on
    #4720# turns off.
    Languages:
    *#0000#+green phone - choose automaticaly
    *#0001#+green phone - English
    *#0030#+green phone - Greek
    *#0031#+green phone - Netherlands
    *#0032#+green phone - French
    *#0034#+green phone - Spanish
    *#0039#+green phone - Italian
    *#0049#+green phone - German
    *#0090#+green phone - Turkish
    How to change PIN2?
    **04*old PIN2*new PIN2*new PIN2#
    What is my software version?
    Menu 8-8-2 press left-softkey when you see IMEI number, or *#06# and then green phone button and then press left soft-key.
    How to extend battery life:
    IrDA - turn on only when you need.
    Turn off automatic network search (6-3)Turn off Vibration alarm.
    Resets language to automatic selection : * # 0000 # then Green button
    S25, M35, S35, C35
    Nov 29, 2007 | Nokia 1100
    Pentax M20 Green Mode Stuck
    i just had the same problem....
    here's how i fixed it...
    turn it on... then as it's loading up... hold the "menu" button
    i think this forces it to stay on...
    i changed the green button to be something else... not green mode
    then i just turned it off and on again
    Aug 20, 2007 | Pentax Optio M20 Digital Camera
    Cameras Logo
    203 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
