Question about Hitachi 43F300 43" Rear Projection Television
Hitachi Projection tv
The left side of screen all of a sudden became blurry and letters on screen have a shadow behind them thta do not line up. Also, have wavy broad line going acroos screen about 5 inches from top. I tried Magic Focus 5 times but no cnange.
  • Hitachi Master
  • 3,459 Answers
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Hitachi Projection tv - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
On the screen I see on the sides of every object a shadow, it,s green on the left side and red on the right side accompanied by some little horizontal red stripes. It started doing it all of a sudden a...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
Red color alignment problem
1) Whenever a rear projection TV has convergence issues, the
fix involves replacement of both IC's = STK392-110.......sub to
STK394-160E for improved durability...........
2) Soldering only is a temporary "fix" at best
3) Do not allow generic IC's, OEM quality or better = I use
Hitachi brand,made by Sanyo,with no callbacks....
4) Skill level needed = above average,....needs chassis pull...T.
Nov 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Mar 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Blue shadow
colored shadows indicate to me a convergence or focus issue. convergence issues can occur on one part of screen. and most recognizable around letters. this might could be adjusted by a technician
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 50+in rear projection tv
If you mean that the 3 colors (reg, green and blue) suddenly no longer line up properly in one area of the screen, it means that one of your convergence IC's has burned out and needs to be replaced. There is no adjustment that will correct the picture in this case. When I do a housecall to replace a burned out convergence IC and realign the convergence circuits, I charge $150 but shops in your area will vary so be sure to ask around.
Sep 18, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
161 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
