I have a Sony TV Model #KD-27FS170. A SonyVCR ModelSLV-N51 VHS. A Apex Model # AD 1500 DVD. MY TV Antenna is outside hooking up to the VCR IN. VCR out to TV antenna IN.Where do I run the rest of the cables to make everthing function. I need a diagram. Thank You O D Taylor
  • 2,427 Answers
Basically its Dvd out the Vcr input
antenna to ant in on the vcr
and then vcr out to tv
and then ant vcr out to tv ant or ant to tv antI have a Sony TV - efdf09b.jpg
Posted on Jul 17, 2008
  • Rishi Roshan Ali Jul 17, 2008
    i hope thats what u wanted,, OH by the way just make sure the color codes match..
    Sergeant:
  • 233 Answers
This pdf should help
http://www.u46.k12.il.us/ehs/letourneauthomas/userfiles/42456_VCRHookup.pdf
  • Darwish Al-helo
    Darwish Al-helo Jul 17, 2008
    this should work for watching tv and recording to vcr.
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
I have a KD-27FS170 FD Trinitron Vega DVD/VHS player. The DVD disk will not eject. What is the solution? Manna
the assembly which moves the dvd door is either got stucked or the gears which moves the assembly needs replacement as they are cracked or worn out.
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Recording from tv to vhs
I would have the antenna hooked up to the VCR. Then you could select any channel that you wish to record on the vcr without the tv being involved.
Jan 07, 2009 | Zenith XBV243 DVD Player/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
I want to convert a DVD to a VCR tape.
Do you want copy dvd movie on VHS tape?
Use DVD/ VHS Combo Player like shown in below picture...
Oct 27, 2008 | Televison & Video
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Insignia dvd recorder
Unfortunately, no, unless the DVD is not copy written material. Commercial DVD and VHS tapes have a built in copy protection called Macrovision. Basically, it prevents copying them with any Macrovision enabled recorder. All DVD and VHS players sold in North America are required to have Macrovision Enabled. Though there are certain players that get around this (such as the Apex AD-1500, in which Macrovision can easily be disabled), unless you research and purchase one of those specifically, you're not going to be able to avoid Macrovision, and therefore won't be able to copy anything to or from a commercial DVD or VHS tape. Hope that answered your question completely, even if it wasn't what you wanted to hear.
Aug 29, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
