Question about HP Compaq Presario V2000 Notebook
System restore Iwant to restore my PC to factory origional setup. my DVD player don't work.
  • 1 more comment
  • jwolters00 Jul 19, 2008
    Thank you for the F11. My DVD drive works for everything but movies. someone suggested the driver is corrupt? It works for program disc, music ect. Thanks again atiqq,
  • Anonymous Jul 21, 2008
    how do go to bios setup
    how do i goes to bios setup
    Sergeant:
    Champion:
  • 256 Answers
Hi
To restore windows press F11 after powering on go advance sitting and restore it.
DVD drive not working not the problem with windows problem with you DVD Drive you need to replace it.. not repairable
Thanks
Posted on Jul 17, 2008
Restore factory default
Check to see if there is a system restore setup for a previous date, this will allow you to roll-back the changes made. You can find this under the control panel.
If you want to restore back to the original windows settings, you need to reinstall windows from DVD or CD, these are backups made when you first got the laptop.
Aug 08, 2014 | Lenovo ThinkPad SL500 Notebook
Tip
Code or other problem fixes fix.
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on Mar 24, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Trouble with Dvd player in Dell Inspiron 530
Find the small pin hole on DVD player and use a straightened paper clip to manually eject in case there is a stuck disc.
Use system restore to roll back your system. Look for a restore point longer than the three days.
I don't see a correlation between the two because the system should work even you don't have an optical drive (CD\DVD).
Aug 30, 2012 | Dell Inspiron 530s Desktop Computer
I clicked completely restore system to factory defaults, but it does not respond
It's probably wanting you to insert some restore discs into the cd/dvd drive.
Some manufacturers leave it up to you to create the restore discs when you first purchase the system. Some put it on the hard drive for you, which sounds like is not your case. Don't sweat it because most times the restore discs that users have to create don't work.
Have you tried doing a System Restore? Click Start/Programs/Accessories/System Tools/System Restore. Select a Restore Point (date and time) before you started having problems. Unlike System Recovery that takes you back to factory defaults and deletes everything, System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Point you selected).
If System Restore does not work for you, then you can always Reinstall your Operating System.
May 16, 2012 | Acer Aspire 5734Z4386 Notebook
If i restore my blackberry bold to origional factory settings do i loose all the apps i bought
No,
On the time of restore factory setting don’t check mark on 3rd parties application
Best Regards & Thanks
Akhtar Mohammad Kalim
Oct 31, 2009 | RIM BlackBerry Bold Smartphone
Need to restore default/factory settings
Check out this website for troubleshooting and repair tips for these dvd players. Just plug in the the web address into your address bar. http://www.drx9000repair.netfirms.com/ This site has lot of information on these units. Hope this helps you with your problem.
May 17, 2009 | Cyberhome CH-DVD 300 DVD Player
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
How to restore factory settings for Coby 755 DVD Player
Ok I'm going to walk you through this...
Turn the DVD player on... give it a second to load up
Now Press Setup.. now navigate down 5 times Press Enter
Navigate down once Press Enter... Or it might just be a Press enter I'm reading from the manual. Click here for the Manual
That is the way to get to the factory default button in the setup.. If your having trouble doing that try using the manual to see where to go to get back to the NTSC settings
May 03, 2008 | Coby DVD-755 System
Restoration disk
Restoring the PC to its original state by doing a system recovery ! Just make sure you back up your important data if you can before doing the system recovery !
1. Plug in the AC adapter.
2. Turn the system on
3. Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4. A screen stating "Starting Acer Erecovery" should appear.
(Release ALT and stop tapping F10 at this point)
5. There will be 4 options:
1. Restore system to factory default
2. Restore system from user backup
3. Restore system from cd/dvd
4. Exit
1. Enter the password created when eRecovery was first started.
2. Read the on-screen warning and choose Yes.
3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
1. If recovery cd/dvd's were created, they can be used to restore the system.
2. Insert disc 1 and follow the prompts.
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Curtis DVD 2100 DVD Player
page 1 in the set up menu will allow u to reset to the factory settings.
Oct 11, 2007 | Curtis DVD1045 DVD Player
HP Compaq Presario V2000 Notebook Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
