I am seeing triple with pink and blue outline on my big screen tv.
    Genius:
  • 1,139 Answers
Hello vman1211
I gave this advice out before and it applies in this case so here goes:
What is happening is that your convergence amplifier modules are beginning to go bad. These amplifiers are what amplify the signals used for convergence (how the RGB lights line up on each other) when they go bad the RGB lights tend to bow towards the center of the TV and the colors begin to mis-align. There are many sites devoted to doing the changing of the amplifiers yourself,however although these sites are accurate and give the instructions on how to change the amplifiers they do very little for actual troubleshooting and finding the underlying cause of the problem. In most cases its just that the amp modules have gone bad, but sometimes there is an overheating problem that triggers the damage. I would suggest having a TV repair person come to your place to check the problem and to fix it. The repair should cost about $250.00 - $500.00 depending on the shop and parts used.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 17, 2008
Lg 42 luv 5500 screens goes pink when turned on.
Try plugging devices into the inputs like DVD, Blu Ray, VCR, Game console, etc. If the screen goes pink on all inputs or at least all the ones you plug anything into (at least 2 different like HDMI and RCA) then it is probably an issue with the screen itself. However it is hard to say when there is so little to go on. information like is there sound or no sound, do you see shadows, outlines etc. or nothing at all, does anything happen when you press menu buttons, will help to see what the problem may be. Secondly how old is the TV? Is it still under warranty or just out? what happened before the screen went pink. what type of TV is it LCD, LED, Plasma, CRT?
If the warranty is still valid go back to where you got it from os contact manufacturer and if warranty is out by about 6 months or less contact manufacturer and try your luck All TVs should last several years at least.
Nov 04, 2017 | LG Televison & Video
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
I have big screen (53") Soni TV that I had bought
Hi this is a common issue on this sets I also have the aame problem with my sony ,whats your model number?
Apr 18, 2011 | Sony Televison & Video
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
TRIPLE IMAGE
This would be the decoder/tuner board giving out, Your going to need to take it in for a replacment of that board.
you can try to unplug it for a while and see if it resets but i doubt that will cure anything long term. Proscan is known for this issue and have been known to have bad decoders in them.
Thanks for being considerate and leaving a ratings and feedback today.
May 29, 2010 | Proscan 42LA45H 42 in. LCD TV
60 inch samsung projection tv occassionally outlines the objects in pink and green.
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Televison & Video
MY TV DIED=(
Your controller board went out inside the TV and needs repair. I hope this information helps you out.
Apr 23, 2009 | Philips 60P8341 60" Rear Projection...
Green, red, and blue lights don't line up on screen
hi you have faulty convergance ic also there may be some faulty resistor and capacitors that sit in front of the ic, thanks
shaun
Jun 27, 2017 | Hitachi 50SBX78B 50" Rear Projection...
Philips big screen projection tv
sounds like the Convergence ICs are getting ready to go. Does it appear as a outline almost 3D? If so its convergence if its more like a glowing halo its coolant in the blue CRT that needs changing.
Jun 20, 2008 | Philips 51PW9363 51" Rear Projection...
Neon Pink outlines around bright images
two points one green and another pink one in the screen Panasonic PT-61LCX65
Jan 30, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
