Question about Uniden Cordless Phone
Cordless phones and dsl router interference
I am looking for an analog cordless phone and will not interfere with my dsl router. I currently have a cheapy 2.4ghz but I heard 2.4 causes interference, so I unplugged it and I have no problem staying connected. Any suggestions?
  • 550 Answers
5.8Ghz works for me
Posted on Jul 18, 2008
Will your internet box interfear with a cordless phone if they are to close together ?
A wireless router and wireless network adapters can have interference issues with cordless phones. It depends on the network adapter frequency and the cordless phone's frequency. Most problems will occur with a phone that uses 2.4GHz. This frequency will interfere with 802.11b/g networks and single-band 802.11n wireless signals.
A DECT cordless phone operates at a different frequency from the 802.11g and 802.11n single-band and will not interfere with a wi-fi network with those modes.
However, some routers and wireless adapters can use the 5GHz range (802.11n and 802.11ac, among them). These can have a problem with cordless phones that use 5.8GHz. However, there is a simple solution to avoid much of the interference at 5GHz. First determine the frequency range of your phone by getting the FCC ID from the base of the phone. Then use Google or another search engine to find "FCC ID Search Form". It has been at http://transition.fcc.gov/oet/ea/fccid/ in the past. The first three characters are the Grantee ID for the search form. The rest is the product ID. Look for the SAR report for the phone and then (probably on the second page) find the TX frequency range and the Max RF output power tested. Now go to the wireless router's setting page and make sure that it is using channels that do not use the same frequency and power range. See http://bradsfavorite.com/avoid-interference-5-ghz-wifi-5-8-ghz-cordless-phones/ below the 5GHz Wifi Frequencies for a table with the channel and frequency ranges for routers.
Once everything is clear, you can visit ScanmySpeed.com and have an internet speed test to ensure that there is no disturbance in your connection.
Nov 01, 2014 | Lands Phones
Tip
Nintendo wii Error Code 61070 fix
Error Code 61070
  • Make sure that your Internet connection is compatible with the Wii console's online service. You must have broadband Internet (Cable, DSL, or Fiber Optic) and a compatible wireless router. For more information, click here.
  • If you have verified that you are using a compatible Internet connection, then it appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies
on Sep 03, 2010 | Nintendo Wii Console
Will a cordless phone interfear with your internet or the cordless phone if its to close to your internet box?
I hope this helps.
My cordless phones crackle
Do you know what frequency the phones operate on? Many devices can interfere with cordless phone signals, including wireless routers, Bluetooth devices, and even microwaves.
Try moving the phones away from any of these devices and see if that helps. If you use DSL for your Internet service, make sure you have placed filters on all of the phone lines that don't go to the DSL modem.
Aug 09, 2010 | AT&T 650530003417 Cordless Phone
There is a buzzing sound on my end of the phone line, my computer is on DSL and sometimes it disconnects when the phone rings. I've checked the cords and the phone has a new battery.
You have interference due to the DSL overlapping your phone line its usually very common, make sure you have a DSL filter inline with your phone line , if not I would check out the RJ-45 jack in the wall, your phone jack and make sure that there isnt anything wrong with your Jack, you may have to call your phone company and have the phone tech's check out your wall Jack for any interference, they have special phone line meters to measure all this out.
Good luck,
Lex...
May 23, 2010 | Uniden Cordless Phone
Very bad stati on ge cordless phone
Often static is caused by RF or EM interference. The interference may be getting into the system though the power or telephone signal cable being near many other cables, or because the unit is situated next to a strong source of RF or EM field.
I recommend changing the location of your cordless phone, away from such noisy sources (microwave, router, DC charging adapters, computers, etc). Try the phone in an outlet that has nothing else on the circuit, if possible.
I hope that helps.
May 02, 2010 | Uniden Cordless Phone
Cordless phone has volume problems with DSL
For starters that dsl modem should not be filtered.
You should place the splitter directly into the wall jack and place the filter on the side used for the phone. The side feeding the dsl line should not be filtered.
The filter serves 2 purposes. 1 it reduces data noise interference onto the voice line. 2 it prevents dsl interference from voice such as picking up and hanging up the receiver.
Aug 26, 2009 | Uniden Cordless Phone
Interference from 5.8 GHz cordless phones
I fixed my own problem. I went to the system setup page for the router and changed the channel to another mghz setting. I found one that didn't conflict with the cordless phones. My son is very happy now that he doesn't get kicked out of Halo3 every time we get a phone call.
Mar 27, 2008 | 2wire 2700HG-B Router (2700HGB)
Will the MR314 interfere with my cordless telephone?
If you have a 2.4 GHz cordless phone, then potentially the 802.11b Wireless network and the phone can interfere with one another. In order to avoid the interference, change the channel on the cordless phone or at the access point.
Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
Uniden Cordless Phone Logo
203 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
