Question about Dryers
Dryer squeak My G. E. dryer make squeaking noise when the drum is turning. However, it only during so, when load with cloths.
  • 1 more comment
  • Anonymous Mar 15, 2014
    my clothes dryer squeaks for first 3 minutes or so,then stops
  • Anonymous Mar 16, 2014
    squeaking in drum
  • Anonymous Mar 31, 2014
    My dryer drum is loose n squeaks alot. How would you tighten it back up.
  • 525 Answers
Your issue is as follows;
"My G. E. dryer make squeaking noise when the drum is turning. However, it only during so, when load with cloths."
Based on the information provided above, I am unable to access my database to provide you with exacting information. You did not provide a valid model number, however, I have provided some common solutions to help guide you in your search.
My Solution is:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Following the link below will provide some information on G.E. dryers.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=784658&PPStack=1
Following the link below shows disassembly procedures for most G.E. models.
http://www.repairclinic.com/0100_20.asp
Rear drum bearing: Most common failure Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 17, 2008
3 Suggested Answers
SOURCE: Squeaks from drum area during operation
I have the same high pitch squeal from drum are after dryer gets heated up. Anyone find what the problem was? Service call help??
Posted on Apr 06, 2008
Richie_asg1
  • 1036 Answers
Hi there!
I think it is the drum main bearing that has started to sieze.
If it is not this, then the drive belt may need replacement.
If this leads to a solution, please take a moment to accept. Thank you.
Posted on Jun 18, 2008
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
Dlb2650bdlwh squeaking noise
The squeaking noise is the result of this
1_6_2012_5_39_24_pm.jpegThing getting real thin to the point that the metal bracket it is in starts to rubbing. The most common one of these is the we3x75. But their are differing part numbers on these dryers. To replace this puppy you gotta remove the drum. It is not as hard as you might think. Pop the top by removing screws or using putty knife depending on your model:
Once you have the drum out the insert goes into the center bearing mount. If that puppy is badly worn you is gonna need to replace the whole bearing mount kit which is less than 30 bucks. Check the glides for wear and clean it up;
More photos are here
Nov 26, 2011 | Hotpoint Dryers
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
Drum squeaks and clothing gets stuck in drum and and stains clothing a rust color
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 08, 2010 | Kenmore Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
Dryer drum squeaking when operating
heatman101
fggf
May 24, 2009 | Fisher and Paykel DE60FA-US Dryer
Hi there!
Jun 18, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
1,746 people viewed this question
Top Dryers Experts
