No cold air blowing out
We have air that comes out of the registers but it is not very cold and the fan on the outside unit will not come on. If we turn air off on the thermostat and then turn it back on we hear a click but nothing else.
  • shulers Jul 17, 2008
    yes the click is coming from the outside unit. You can only hear it if you are actually outside by it.
  • James Helmer
    James Helmer May 11, 2010
    Where is the click sound heard? Such as at the outside condensing unit?
  • 828 Answers
Check for power at the outside disconnect and main circuit breaker in the main power panel of our house. If you have power at the disconnect and the contactor is clicking there may be a loose connection or burnt off wire at your contactor. There is a removable cover on the unit where the wire connections are and you can inspect it by removing said cover. If repairs are necessary disconnect power and remake connections.
Posted on Jul 18, 2008
My air conditioning unit is leaking water on the ground outside. Also the air upstairs in not coming out. It's working in the basement. What could be the problem?
It is normal for an air conditioner to drain water outside.
The lack of air flow upstairs could be due to closed or blocked registers.
Aug 07, 2017 | Heating & Cooling
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
several possibilities inside fan not running,dirty coil,duct work problem. turn tstat to fan on position see if it make a difference.
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Fan on outside unit cuts off for an hour or so while unit should
Hello Rett Check the fan selector switch setting on the thermostat.It should be set to AUTO position instead of ON.
Jul 15, 2010 | Heating & Cooling
My a/c unit does comes on but it only warm air not
Make sure the outside unit is running, compressor and fan. Sometimes it is hard to hear the compressor over the fan. If the outside unit is not working check circuit breakers first. Set thermostat to call for a/c and make sure the contactor in the outside unit pulls in. If it does check capacitor for whatever is not running. If everything seems to be running fine hold your hand above the fan outside. The air coming from it should be hotter than the outdoor air. If it isn't get the refrigerant charge checked.
Jun 29, 2010 | Goodman GPC1342H21A Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
No cold air coming from the registers.
If your compressor is running outside (low hum noise) then your probably need freon .If the compressor is not running could be a bad cap or bad compressor
May 22, 2009 | Heating & Cooling
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
