Question about Microsoft Xbox 360 Console
Resolution What is a better resolution for an xbox 360? 1280x1024 1360x768 (These are the highest my monitor supports) And what references levels would be best with the best resolution.
  • 4 more comments
  • Sibbi Jul 17, 2008
    Its a Sony LCD Display. 19 Inch I believe.
    the model number is sdm-hs94p
    thank youuuuuuuuuuuuuuu so much
    Just a question what would 1280 x 1048 be equivalent to? Like 720p or lower?
  • Martin Carr May 11, 2010
    Have you got the model number ?
    What monitor do you have?
  • 22 Answers
Your monitor is 4:3 and a maximum resolution of 1280 x 1024. Therefore you want to set your 360 resolution to 1280 x 1024 and you may want to change it to widescreen if desired. However, widescreen will cause you to lose some of your screen (i.e Letterbox). Try both standard and wide and see what looks better for you. If you are right up close to the monitor (about 12-18 inches away for instance), then widescreen would be ideal.
As for reference levels, it will depend on the contrast of your monitor. Try it on all three settings and see which one looks better for you. There is no wrong or right answer!
Posted on Jul 17, 2008
  • Martin Carr Jul 17, 2008
    720p is 1280 x 720, so 1280 x 1024 is a higher resolution. However, if you run Widescreen mode, you reduce the vertical resolution to 720 (black bars) making it the same thing!
Increase resolution
The poster resolution and the computer resolution are completely separate. The cpt resolution controls the monitor screen display. The poster resolution refers to the camera pixels used in recording the original picture - it cannot be increased. The poster program is measuring the resolution of the file picture only and indicating that t will produce a blurry poster.
May 29, 2014 | Computers & Internet
Acer display drivers for mac-mini ?
hi, may I know how are you connecting the mac-mini to the display? if it is VGA, that is the highest resolution it can go. But if you're connecting it via HDMI or DVI-D, it can reach its highest resolution for the monitor. did have similar problem last time, but solved by using HDMI-DVI cable.
Jan 01, 2014 | Acer AL1917W LCD Monitor
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
Stretched screen
For best graphics and zero stretch select the highest resolution that your LCD supports. Which is the resolution of 1440X900
Right click on your desktop and select properties.
Click the Settings tab.
Slide the resolution Bar to the resolution of 1440X900
Also select (Highest 32Bit) colour quality on the right of the resolution bar.
Click Apply then Ok.
If you are not able to select the resolution of 1440X900 then you should update your graphics card drivers to the latest version.
To download the latest drivers for your graphics card click here.
Select the following:
Geforce
Geforce 5 FX Series
Geforce FX 5500
Select your operating System
Select your prefered language
Please be sure to rate this session.
Take care!
Norman-Wynne Damstra
Nov 14, 2011 | Belinea Maxdata 1925 S1W LCD Monitor
I have a LG Flatron W2242p monitor. What should I set the screen resolution setting to?
1680 x 1050 is the highest resolution that this monitor can support.
Go through my published guide entitled How to set your Desktop Screen Resolution?
Set your Resolution to 1680 x 1050 as this will give you the sharpest image.
Thanks
damnor01
Jan 08, 2011 | LG Flatron W2242P-SF 22" Monitor
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
I got the problem too, today...
Check the specs for your video card. Just because the monitor can handle that resolution does not mean that your graphics card can. If it cannot then you can either upgrade the graphics card to one that will support the resolution or you'll have to use the highest resolution that your video card can support. Hope this helps.
Jul 08, 2009 | Samsung SyncMaster 920NW Monitor
Resolution to big
Check your grahics card to make sure it supports higher resolutions. It may be that you have it already set to highest supported by your video card. Hope this helps.
Dec 27, 2008 | Envision H190L Monitor
Screen resolution
1680 x 1050 at 60 Hz is the ooptimal resolution and the only one that will not be fuzzy.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
press command - shift - a to bring up the Applications folder. Then open System Preferences. Click on Displays, from there you should be able to adjust the resolution
Oct 10, 2006 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Microsoft Xbox 360 Console Logo
55 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
