Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Do not know how to transfer pictures
I took some pictures with my new camera and was told to just insert the SD cart into the computer to transfer the pictures taken. However, there is no SD slot in my computer. What should I do?
You need to buy an SD Card reader. They can be bought for at least $10 and will plug directly into a USB port on your PC
Posted on Aug 08, 2008
Trying to transfer photos to computor, hit transfer and it comes up Failed to initialize pluto. Don't know what to do.
You didn't say what software you are using, but there are better ways to download your photos. The best way is to connect your SD flash memory card to the computer. If your computer has a SD card slot you are in luck. If not, you can buy a USB SD reader for under $20 on line or in any computer store.
To use it, remove the SD card from your camera and insert it in the reader. Your computer will automatically recognize the SD card as an external memory device; exactly as it does with an external hard drive. You can then open the SD card and access the folder with your pictures. All you need to do is copy and paste your photos from the SD card to a new folder on your computer. It's that simple. Almost all professional photographers use this method and do not transfer pictures from the camera with the SD card in the camera.
Aug 17, 2015 | Nikon D5100 Digital Camera
Why is my nikon coolpix L26 not uploading my pictures
First, use the review function to make sure your camera actually took the pictures. Assuming it did, I would remove the SD memory card from the camera and use a card reader to transfer the pictures to your computer. If your computer does not have an SD memory reader, many USB readers are available for under $20. They are USB devices and once they are attached to your computer and you insert the SD card, the computer will act as if the SD card is another external hard drive. You will be able to transfer your photo files from the SC card to a file on your hard drive via copy and paste or drag and drop. Although you can erase your card when you are done by deleting the files, it is better to put the card back in your camera and use the format function found in you camera's menus.
Jun 19, 2014 | Nikon Coolpix L26 Compact
I am having a problem transfering pictures from my Kodak EasyShare C1013 camera to the computer.........any suggestions, it will transfer a few but not all the pictures. Thank You
The easiest and fastest way to transfer pictures/videos from your camera is by removing the SD card from your camera and insert it into a SD card reader. You can buy card readers at any computer stores at cheap prices. You insert the SD card into a card reader and then you insert the card reader into a free USB slot on your computer and then you can copy ALL your files then wherever you want.
Thanks for using Fixya!
Jun 17, 2011 | Kodak Cameras
Have several pictures on the camera but no SD card in it. Cannot get them to transfer to PC or laptop. How can I either put card in and transfer or transfer to PC?
Hello, and thanks for using FixYa.
the camera has a sd card slot, insert a appropriate SD card to the camera, navigate its menu and find COPY TO CARD feature.
after the pictures are on the card, remove the card and connect it to a card reader which you can then connect to a computer.
or use appropriate usb cable to connect camera to the computer, then open "my computer" or computer from either desktop or start menu, then find removeable storage device and pictures inside. That is the same way a card reader would work.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Oct 22, 2010 | Vivitar ViviCam 4100 Digital Camera
Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Jun 17, 2010 | Kodak EasyShare Z710 Digital Camera
Every time i take a picture on my camera it says memory full insert a Sd memory card to transfer and take more photos i havent took any pictures and i inserted a SD memory card
Try this...go into the menu and scroll to "reset"...follow the on-screen instructions. Then, without a card in the camera, go into the menu and scroll to "format"...follow the on-screen instructions. Then if the pics on your memory card are safely on your computer (use a card reader to do this if necessary) insert the card into the camera, go into the menu and scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Nov 22, 2009 | Vivitar ViviCam 8025 Digital Camera
I took picture w/o SD card. Don't know how to transfer to SD
Search the menus for an entry for "copy". It should give you the option to copy the internal memory to a memory card. You could also take the camera and a usb connecting cord to a store like Walmart that has a Kodak picture maker machine. You can plug the camera into the usb slot and print the picture.
Sep 11, 2009 | Samsung Digimax S730 Digital Camera
SD Card Issue
Usually when you take pictures using NO SD card you can't take the picture, however in this case the pictures you took are stored in a memory bank temp only to test the picture your actually taking. In the manual what's the size of the built in memory card? Usually it's small amount of memory built in
Sep 07, 2009 | Samsung Digimax S730 Digital Camera
I have an A 520 polaroid digital camera with a memory disc in it. I took pictures on it and want to download the pictures onto my computer. When I insert it in the drive nothing happens. what is wrong?
You mean SD card, right? You can insert the SD card into a card reader and then access the card from the disk driver letter that is assigned to it. Simply open My Computer (if Windows) and check the drives.
But you can also use a USB cable to connect the camera to your computer. Using the Picassa program from Google, it is very easy to transfer the photos to your PC.
Jules
Apr 20, 2009 | Dell Computers & Internet
How do I take pictures from my memory and put them on my SD card?
You'll have to buy the charger/station for S5. No other cord fits your nikon unfortunately.
Mar 29, 2008 | Nikon COOLPIX S5 Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
