Question about Xerox DocuColor 12 Printer
PROBLEMS WITH FIERY AND DC 12
The Fiery X12E a message of CHECK POWER AND CABLE, the solution APARETE to verify cable and shutting down equipment, but when Prendes DA another message to turn off your printer and re-pledge and CONTINUE THE PROBLE...
  • pollitomuert Aug 01, 2008
    The Fiery X12E a message of CHECK POWER AND CABLE, shutting down equipment, but CONTINUE THE
    PROBLEM
I am same problem in our dc 12 fiery display cheak cables but machine display turn power to the printer ON. how to solve the problem
Posted on Oct 15, 2012
I am having same proble and say turn printe off and on on fiery and in machine it is showing check consumable management with system administration
Posted on Aug 22, 2008
  • 79 Answers
Pls u check the fiery and dc12 printer cable. if u have another cable pls replace and chek that also. i think the problem is in only the connectres. u remove and clean all conctres and refix. maybe the problem solved.
Posted on Jul 23, 2008
I have a docucolor 12 and x12 fiery. I am trying to calibrate from the fiery. It will printer calibration page, but it can't measure scanner. It comes up with check scanner cable connection. I have tried...
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
Jan 02, 2011 | Xerox DocuColor 12 Color Copier
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
I have got a Xerox Docucolor 12 printer, a Fiery X12, and a laptop running on Vista. I dont have any cables except the power cables and was looking for a list of everything I'd need to get it running...
There are 2 cables that go between the fiery and the printer, not sure where you can get these.
You will need to be running windows xp
connect to the fiery with an ethernet line
download the drivers, command workstation, and fiery remote scan from the xerox website
hopefully the fiery still has its software loaded otherwise post a request for a copy here.
Nov 11, 2010 | Xerox DocuColor 12 Printer
WHEN I TURN ON THE FIERY IT START AND AFTER THAT IT GO TO BOOTING
First I would try to power-down the fiery and disconnect the power cable for 30 seconds or so then try to re-start. If that does not work then it sounds like you need to reload the software on the fiery, don't forget there may also be patches you need to install. This takes several hours. Xerox protects that Fiery software so you may have a hard time finding the cd's if you don't already have them. The patches are a no charge download from the Xerox website.
Sep 29, 2010 | Xerox DocuColor 12 Color Copier
Clc1150 cannot connect to fiery
Your Fiery need"s system software reloaded. let me know if you need help to do so.
May 11, 2009 | Canon CLC 1150 Color Copier
CAN'T PRINT FROM FIERY X12E
That happeng to me before, i just low the resolution that fix the problem or flat the image before you send that help too
Mar 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Not Printing with another Fiery
could be a few things, the ips pwb in the machine might be faulty, which can cause these types of issues, a driver issue woth the video boards on the fiery, or other pwbs on the machine itself. You would have to run the machine for a while on another fiery to make sure no other faults occur before condemning the machine or the fiery
Jan 17, 2009 | Xerox DocuColor 12 Color Copier
sir u do first one thing
1,check cable betwen fiery & dc 12 machine
2, press 0 + start enter code 6789
3,go to nvm read/write
4,enter nvm 759-053 code -enter 1
5, next 759-054 code-enter 1
Dec 09, 2008 | Xerox DocuColor 12 Printer
Fiery cannot transfer the printing jobs to dc-12
have you tried replacing the cables maybe they are in a incorrect position wen you do this switch off the fiery and the machin.
Mar 25, 2008 | Xerox DocuColor 12 Printer
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
617 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
