I have a iBook G4 1.33 that is not starting up. It will get to the flashing folder icon. I can start form a CD or from and external firewire drive but the internal hard drive does not show up even though I have put in a HD that I know is good.
  • Harold Jul 17, 2008
    I agree then i thought I was posting on an Apple iBook Forum. Such is life. Thanks
    Problem Solver:
  • 63 Answers
Perhaps a different forum?
Posted on Jul 17, 2008
Ibook G4 and fantom firewire drive
You will need a power supply.
Jul 01, 2013 | Computers & Internet
Fantom drive volumeSerial No.12072
Disconnect the external firewire drive. Start the Disk Utility app in the Utilities folder inside your applications folder. With the Disk Utility window open, connect the external drive and power it on. It should appear in the left column. If not, your drive has probably failed and may have to be replaced.
If the drive appears, select it, click First Aid, then Repair Disk. Wait for this testing and repair to complete. Any problems should be resolved. If the display indicates irreparable disk problems, you may be able to use the Erase function to reformat the disk - but you will lose all the data on it. If repair seems to work, select the drive in the left column and click Mount in the toolbar. From the desktop, open the drive and see if data appears to be accessible. If so, close Disk Utility, restart your Mac and see if the external drive seems to work (repairs can cause some loss of data, but generally you won't be aware of the loss).
If you don't do so now, you should set up a backup of anything you don't want to lose (and we recognize you might be using the external drive for Time Machine). Disks crash and die. You should have a good backup when they do. Time Machine is your friend. Use it.
Jul 01, 2013 | Apple iBook G4 (Z0AZW13397068) PC Notebook
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
When i turn on my ibook A1133 a folder flashes with the finder icon then a ? question mark and is unresponsive to the keyboard or trackpad
click start control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
hope this helps
Jan 01, 2011 | Apple iBook 12 iBook G4 1.33GHz,...
A1005 Battery and power supply fine - but not starting
A1005 is an inexact marketing identifier covering pretty much the entire line of G3 iBooks.
Complete failure to start -- unless it is caused by something trivial like a broken start button -- without any startup or error tones, points to basic logic board failure. A machine this stone dead for no apparent reason is unlikely to be revived, and almost certainly not by third-world techs who don't know Macs. It is debatably cost-effective to resuscitate a sub-GHz G3 iBook from such a failure, compared to replacing the unit with another new or used Mac. The drive in the old Mac can be extracted so as to preserve your data, and can be inserted into an external USB or FireWire case to be accessible to a new Mac.
Oct 10, 2009 | Apple iBook Mac Notebook
My mac is showing me a grey screen with a flashing folder icon in the middle alternating the finder icon and a question mark.I dont have the osx disc
The flashing folder icon is telling you that your Mac cannot locate a working operating system to startup.
You may be having a software problem that is keeping your Mac from recognizing your operating system, or a hardware problem that is keeping your Mac from connecting to your hard drive (where the operating system lives).
Since you don't have access to a CD/DVD of the Mac operating system, ff you have an external hard drive with a working operating system on it, try connecting it to your Mac with FireWire and startup the computer holding down these keys: Command (Apple) +option+shift+delete. This will force the Mac to attempt to startup from the external drive.
If none of these things work, we would be glad to help at TechRestore. You can use coupon code "TWEET" for $10 off any drive replacement service. We offer free shipping options and local pickup in your neighborhood. http://techrestore.com
Hope this helps!
TechRestore
Oct 01, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
EMac stuck on loading screen
Well i don't know of a fix for the issue u have, but i do have a tip and you might be able to fix the issue you have this way as well. But if you plan on transfering files from one mac to another esp. if one is either an older mac or a portable. you would always want to make one or the other a target disk instead of two stand alone mac's.
Why, because your eMac's older and the data transfer might be failing or can't process the data fast enough to get broken down to bits to be put back on the other end thru the cat5 line. But to transfer files of over 1 GB i would recommend you start the iBook in target disk mode. But since your eMac is the one with some issues put the eMac as the target.
To connect two mac using TDM (Target Disk Mode) you will need to get either a 6-pin IEEE to 6-pin IEEE firewire 800 cable, a 6-pin IEEE to 9-pin IEEE firewire 800 cable, or a 9-pin IEEE to 9-pin IEEE (if your eMac has a 9-pin port) firewire 800 cable.
Then you connect the cable to one of the eMac's 6 or 9 pin ports and the other end to one of the iBooks firewire 800 ports. (the iBook has both the 6 pin a48d559.gif and the 9 pin. 24a3000.gif800 ports) To start up as the target disk you press and hold T immediately after pressing the power on button. once you see the firewire symbol bounce around the screen you can let go. Now its like connecting to a external hard drive.
Jun 18, 2009 | Apple eMac Desktop
Grey screen folder icon flashing and alternating with ?
The computer can't find an operating system. Start up from the OSX disc and check the drive with 'Disk Utility'. The system may have got damaged, or the drive may need to be repaired. Run 'First Aid'.
Apr 10, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Just repaired g3 ibook. Hard drive needs formatting, as it has xp loaded on it. Ibook starts up, boot tone, proceeds to load, then screen has a file in the center of screen with the osx finder square face...
With the OS X Installer CD in the drive, try booting your mac and holding down the option key immediately after you hear the start up chime. This will (hopefully) load a firmware boot loader that will show available start up discs. Hopefully the OSX installer will show up as CD Icon. Select the Icon with your mouse or keyboard and press enter to start up with the Installer CD. From the installer you should be able to erase and format the drive as Mac OS Extended before installing OS X.
If the computer still won't boot from the CD double check that it is a retail OS X installer CD. If your CD has "software restore" or "ibook restore" or any other varient of restore written on the label; or if it names a particular model such as "ibook install" or "imac install" it is not a retail copy and may not be a bootable disc. A retail copy will only name the version of the operating system followed by the word install written on it's label and usually have a brief instruction on booting from the CD by holding the C key at startup.
Hope this helps, let me know what happens.
Apr 03, 2009 | Apple iBook G3 Mac Notebook
Ibook g3 wont startup.
It's probably a problem with the hard drive not being able to be mounted. This can happen when some of the important sectors of the hard drive become corrupted or damaged somehow. The best thing to do is to start with an OS X cd (hold down c after the boot up chime to boot to the CD). When you've done this then cancel the install process and go to tools and use the Disk Utility to repair the drive. I'm guessing that you'll find that it fails because the drive has some serious problems with it.
You can keep trying various stuff, but you'll probably have to reinstall OS X to get it working again.
One thing to try is to use it as a firewire drive (hold T while starting the computer) and then connect it by firewire to another ibook so you can get your Home directory off it and save your data. I'm guessing though that this won't work because the hard drive isn't able to be "mounted" (accessed). Write back if you have more ??s
Nov 09, 2008 | Apple iBook G3 Mac Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
