Question about Tatung V30DMTT 29.6 in. LCD Television
30" lcd hdtv monitor
It won't come on
  • hdavid Aug 16, 2008
    Lost signal to unit and assumed it was a failure of the signal from AT&T U'VErse cable. Cable guy came in and said that the unit is powered off. Tried powering it on but no luck.
    WE have unplugged the unit hoping it will discharge/recycke and come back on in a day or so.
    Any thoughts? Sefvice Centers?? Bought unit at Walmart.
  • nicnoc1383 Dec 13, 2008
    I turned mt tv off at 10a and tried to turn it back on at 3p and it would not come on and neither with the red light on the tv.
    Problem Solver:
  • 6 Answers
I have the same unit. My power supply unit failed. I got a new one from the dealer for $70.00. The # is 915-771-7554.
Posted on Oct 22, 2008
I have a VIZIO VF550M LCD T.V. I was watching T.V. and it went off and won't turn back on. What can I do to fix it?
Outside of leaving it unplugged for 30 minutes to do a reset, there's not much you can do. It sounds as thought the set needs repair. Sounds like you have an issue with either the power supply or main board
Apr 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Power button is stuck on Monitor. It won't depress or turn on.
clean with alochol isopropyl by 30 minutes let it dry. and try again.However if the problem persist, TIME to replace the power button.God bless you
Apr 04, 2013 | Dell E207WFP 20" Widescreen Flat Panel LCD...
My Compaq 172 monitor won't stay on but for maybe 30 seconds then goes blank. When it does this, the on/off button is still lit up, but I have to lush it manually to get it back on for about another...
Failing Power capacitors. The capacitors hold the charge necessary to build up the voltage that lights the screen. When they leak or fail to hold the charge, the screen will cut out. It could also be a fault in the switch circuitry. Really needs looking at by a qualified technician.
Jul 21, 2011 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Sharp Aquos 30" monitor only
The monitor will not work without the AVC box.
Do you still have the monitor? Is it in good condition? Would you be willing to sell it? If so, please email me at
Apr 17, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
My sharp aquos 30 inch tv will not come on. what could be the problem
Hello; I have an similar LC30HV2U for sale in my TV repair shop for $350. This is a 2 piece unit. The AV box and the monitor. I am also a Sharp authorized servicer. In the monitor there are 2 inverter boards on the right side that have an 80 % chance of causing this problem. This set counts "lamp errors" due to one or more inverters not working on startup. Once the set accumulates 5 lamp errors, It will not allow the set to come on. The first thing Sharp tells us is to replace both inverter boards. About $90 each. If those don't fix it the cost will go much higher due to a bad power supply board or bad LCD Panel. Hope this helps, John
Jan 02, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Where to find replacement LCD for Cracked 30
You can try contacting Apple tech support
They will be able to give you the best solution
Dec 17, 2009 | Apple Cinema HD 30" LCD Monitor
Scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Nov 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I cant tune in the freeview channels on my brand new lg lcd tv
Have you completed the entire auto programming?This can take up to 30 minutes and if you don't complete it you won' get any digital channels.If you have done this then you need a new main signal board.Call lg and they will refer you to the nearest service center.
Nov 10, 2009 | LG 37LH30 37 in. LCD HDTV
Polaroid 15" HD Widescreen LCD 1511-TLXB, turn on, stays on for about 30 seconds to 1 minute and then screen goes black, no sound, no menu
Do you have to turn it back on with the remote after this?
If so, then you may have set a timer by accident through the menu system.
More information would be required.
Aug 04, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Tatung V30DMTT 29.6 in. LCD Television Logo
59 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
