Question about Xerox WorkCentre M123 Copier
Workcenter m151 all i get is two large balck lines both sides of the page how do i go about repairing it
    Scholar:
  • 53 Answers
Not enough information......
Does the problem when copying on the glass...through the document handler....printing...is there part of the information you expect to see there with the black lines over the top, or JUST the black lines ?
Posted on Jul 19, 2008
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
When I print, there are two line balck lines and two faded black lines running down the middle of the page.
i think it is a laser printer.
In laser printer when the drum got damaged (inside the cartridge ) may leads to this state.
so check it out.
Mar 16, 2011 | Office Equipment & Supplies
Ice maker does not seem to be getting water, I have seen talk of makeing sure line is not frozen, but my supply line is between the liner of the freezer, I can't see if it is frozen. Small balck part where...
By "small balck part" I assume you are talking about the water valve at the bottom of the refrigerator.
If so, you might try a couple of things. Pull the water line off the valve, and (if you can get close enough to it) blow through it and see if there is a blockage. Another alternative would be to run something fairly stiff but also flexible up the line. (Plastic weedeater line is often good for this.)
If the line is open, either the water valve is bad or the icemaker control is not calling for water.
Oct 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Zerox workcenter m151 when i print i only get on both sies of page light coverage not readable copy if i copy with cover open i get two solid black strips do i neeed a new drum or is it something...
Your toner is empty and just not indicating it's empty.
There is a light sensor and windows through the cartridge. Sometimes there is a little ink left on the window and it doesn't report empty.
Jul 17, 2008 | Xerox Office Equipment & Supplies
Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Apr 11, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre M123 Copier Logo
164 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
