Question about Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck
Cassette Tape Deck Problem
This tape deck is 8 years old. The electronics are OK. The only problemis with the tape transport system, which apparently is worn out. Itmoves OK in either direction (forward or reverse) but hangs up whenchanging direction. This happens with both decks.
This same problem happened about a year ago. A service technician inthe Pasadena area "repaired" it by replacing two belts, but afterabout 9 months, the same problem occurred.
    Sergeant:
    Champion:
  • 319 Answers
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Posted on Aug 03, 2008
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
Denon DRM-740 stops
This may mean the takeup reel is intermittent or that he cam system of the transport is not getting the correct feedback. I have hd some decks that had very little back tension and they would skew tape- and the audio would be gone before they would shut off. The deck need restorative work done to it and now is the time before is eats all your tapes up.
Feb 22, 2014 | Denon Audio Players & Recorders
Teac x1000r transport logic does not work
Are the tension arms up? if so, the unit needs looking at to determine the cause of the fault. These X series decks are not the easiest units to get corrected because of the many features and the servo tension system they employ. I have one on the bench now and have been doing Teac decks for over 40 years. I can help if you need a Technician and I can direct you to guys I know if you are no near Chicago.
Mar 17, 2013 | Audio Players & Recorders
Tape transport failure on tc-366, motor noise but no tape movement
These units are mechanically in need of a good cleaning and application of new grease in the slide plate mechanism. The Play idler that was in the last one i rebuilt was sent off to Terry'srubberrollers.com to have it get new rubber on it. There is certainly a lot of work to be done on these units but they can be made to work again. Personally though, I would just get a Teac A2300S or SX and use that as the overall maintenance and longevity will be better in the long run. I have serviced hundreds of them and I still do. The design of the Teac is not so much dependent on all kinds of mechanical parts as the Sony is. The last TC366 I worked on took about 4 to 5 hours to correct all it's problems. Then when you are done you still have a lever activated deck where the Teac is a solenoid deck with remote capability. I worked at both Sony factory Service and Teac Factory Service so I have had experience in each item.
Aug 24, 2012 | Sony Audio Players & Recorders
Pioneer Cassette Deck Repair
Anything that eats tapes means the take-up torque is low of stopping due to bad belts or a bad Idler system or even cracked tires. The transport have to be taken out and those parts replaced and then it will work again.
Feb 05, 2012 | Pioneer Audio Players & Recorders
Cannot diengage tape heads . transport will not play or record but will rew and fast forward
The reel motor drive is independent of the head base actuator system.
You may need a new belt for the cam system or possibly a gear depending on what they used in this transport. This is a job for a Technician. I have not worked on one of those recently but have done thousands of other Teac and other brand decks over 40 years.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
RE:JVC CASSETTE DECK MODEL # KD-D4J,PROBLEM, TRANSPORT JAMMED WITH CASSETTE INSIDE,ALL BUTTONS/CONTROLS INOPERATIVE? OPENED UNIT AND MANAGED TO REMOVE CASSETTE ,DID NOT USE UNIT AGAIN. THIS PROBLEM...
it sounds like your tape heads are worn they will strip your cassettes every time and give you very poor sound reproduction it can be repaired but costly to be honest you would be better off with a new deck and it will be cheaper all round.
Mar 27, 2011 | JVC Audio Players & Recorders
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Sony cassette deck tc fx 210
Define 'skip' in the context of your CASSETTE deck.
Poor audio is usually due to damaged media or dirty transport (heads, pinch rollers and capstan).
You can see the tape inside the cutouts of the cassette shell. It should be perfecly smooth and the edges straight. Use reflected light to evaluate it. Edge damage will affect the Left Channel most.
Dirty heads will cause loss of high frequencies first.
The transport, well, if we need to explain it to you then we KNOW it's never been cleaned.
See this helpful link.
http://www.fixitclub.com/Electronics/Cassette_Deck.shtml
Mar 05, 2010 | Audio Players & Recorders
Playing a tape on Deck B stops after a few seconds. Tried over and it stops again after a few seconds of play.
Either tape is tight, run it ff the rev all the way back, or transport is failing , motor , belt , pulley etc,
check tape or try another one in deck b, how is deck a
Sep 21, 2009 | Onkyo TARW255 Single Dual Cassette Deck
Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck Logo
427 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
