Question about Philips HTS3450 System
I am having the same problem mine made the clicking sounds and now won't make any sound. I took it apart and located the capacitors. How do you change them/is it difficult? (capitol.hills@hotmail.com) I would appreciate any help you could offer. Thanks, Mike
  • 20 Answers
You have to have soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast!
Posted on Jul 26, 2008
I have Samsung UN55EH6050 TV with sound but no picture
check this out..
Samsung power defect causes some TVs to fail and class action suit follows
Watch this video.. ( I did mine - three times - before I bought a LG).. its not hard.. just a little time... the local TV repair shop can install these for you..
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
watch the + and - sides when installing..
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
Sep 08, 2017 | Samsung Televison & Video
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
Philip tv no picture no sound
JUST A SUGGESTION..
Oct 30, 2011 | Philips 52PFL7422D/37 TV
Philips tv model number 50PFP5332D 37 wont power up
JUST A SUGGESTION..
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Screen goes black but still sound
JUST A SUGGESTION..
Oct 23, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
My lights, windows, and radio all work fine. But it won't start it makes a click noise but nothing. Then we thought it was the battery so we jumped it and now it won't even make no click noise at...
The "click" sound condition make us guess that could be a bad ignition switch or starter.
It turned out to be the starter. I first took the battery to have it tested and it was fine. Next, I took the starter apart and took it to Autozone to have it tested? and it was bad. It is not easy access to remove the starter. The intake manifold and exhaust system are in the way and need to be taken apart first. See instructions below:
- Take off Intake
- Take off Starter
Hope this helps (remember to rating this answer and leave some comment).
Sep 28, 2011 | 2003 Honda Element
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
Magnavox 37MF231D 37" LCD TV "popped" now won't turn on at all!
Capacitors tend to pop when they fail. Phillips LCD TVs have lots of problems with capacitor failures in their power supplies. I've got my 37mf231d apart on my workbench as we speak. Mine makes a whistling sound which I believe is either a solder fault or a bad capacitor.
A new power supply board is about $150 for that TV. The gamble, of course, is if the power supply took out something else when it failed.
Jan 16, 2009 | Philips 37MF231D 37 in. LCD Television
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
TH-42PX80U
i have the same problem but i have 11 blinks
Aug 13, 2008 | Panasonic TH-42PX60U Television
Philips HTS3450 System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
