Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
I have a shop vac. model 500x 1h.p. Center section speratedon impeller cost of new ? or throw away ?
  • 281 Answers
If it didn't cost you too much i would throw it away and buy a new one.you might want to call a repair shop and get an idea what it would cost to repair.my guess it probably won't be worth it
Posted on Apr 10, 2009
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794495
Generic problem for all Vacuums
I have a shop vac.
Posted by mymino on Jul 17, 2008
I have a shop vac. model 500x 1h.p. Center section separation impeller cost of new? Or throw away?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are only 2 ways that I can think of in answer to your question. Either you can replace the fan impeller or you have to replace the entire motor. You would have to contact your local vacuum cleaner dealer in your area or contact the Shop Vac factory @ the website or to call the factory @ the phone 3 listed below; or check your owner’s manual.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
Shop-Vac Corporation
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 17, 2008
I need a caster foot for the shop vac qps20
Best thing you can do is pull the other three off and throw em away or else glue them on the wheels being detachable means they get lost every time
Sep 24, 2015 | Shop Vac Vacuums
Shop-Vac 6.0 hp Peak 12 Gallon 'Exploding' after 10 seconds of use. Happened twice on two different brand new Shop-Vacs.
Since you said you were sucking water out of a "trench" I would bet there was some debris in the trench that impacted the impeller on the vacuum and caused the metal impeller to fragment, taking the plastic pieces with it. It is highly unusual for this to occur on vacuums if some type of debris, such as a small stone or piece of metal does not reach the high speed impeller/fan. I suggest using either a foam sleeve over the filter cage, or an old nylon stocking if you can get one, to screen out the debris that will cause this condition.
Nov 20, 2013 | Shop Vac Vacuums
Qul650 shop vac
In most of the current model Shop Vacs, the motor is virtually the last thing that will come off the top of the vacuum itself. There are no repair parts available for the motors, but if it's under warranty, the company will send you a complete new power unit., motor and all. All you'd have to do is unpack it and install it on the tank.
Oct 22, 2013 | Vacuums
What makes a bissell vac 3130 throw out dirt instead of sucking it up? i just changed the belt that was broken.
Does your vac require you to twist the belt and fit it onto a shank on the impeller? If so twisting the wrong way will make your beater bar roll the wrong way and that will make it throw dirt out the front.
Mar 12, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Removing impeller from sears shop vac
The impellar will screw off with a clockwise rotation and the new one installed with a counter-clockwise movement.
Aug 21, 2009 | Vacuums
Parts list for model: EP754 The plastic  hose connecter from hose to vac cracked i need new connector
Shark vacuums generally are not repairable - in this case, Shark doesn't sell just the part; ya gotta buy the entire power head. And it costs more than the vacuum did new.
Shark's are considered throw-aways; when they break they're done.
It'd REALLY be nice if Linens 'N Things hadda told me that BEFORE I bought the vacuum.
And by the way, LOTS of EP754s break in the same way yours did.
Jul 17, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Feb 07, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Has no suction
I just went through the same thing.  Your fan or impeller is probably broken off the shaft and no longer on the motor shaft.  My local repair shop wants $9 for the impeller and $29 to replace it. You will have to take the thing apart and put on a new fan or impeller blade and I'm still trying to do that to my vac.  I think I will have to heat the nylon impeller with a hair dryer to get it onto the shaft and then tighten the left hand nut. My vac is held together with torx screws so add a torx screwdriver to the price if you don't have one and want to do the job yourself.
Aug 19, 2007 | Eureka Whirlwind 4383 Upright Vacuum
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
700 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
