Washing machine growls slightly when filling with water but only on cold setting.
  • marciatoby Jul 17, 2008
    I changed the water filling valve and that fixed it.
    Genius:
  • 1,028 Answers
Try shutting off water slowly till sound disappers if washer fills ok leave it alone a new fill valve may help but if works ok save your money
Posted on Jul 17, 2008
My F&P WA75T65GW1 will not fill to rinse after the wash water has been pumped out. If I manually fill it, it will continue the cycle. Are you able to help? Thank you
when you wash do you set the water temp to warm or hot? it may have a broken cold water valve and may be filling with just hot water when washing instead of both, so when it gets to the rinse it cant fill with cold water, if you set it to just cold water does it fill on the wash?
Jan 31, 2017 | Washing Machines
Whirlpool Ultimate care 2 washer doesnt fill on start or rinse or spray in spin all other functions fine whats wrong?
The water valve has a 'Hot' and 'Cold' side, make sure to test if the unit will fill at a different water temp. setting, as a Cold/Cold setting will paralyze the machine if the Cold side of the water valve has failed... Some newer machines have temperature sensors attached to the valve and will not fill if the sensor fails... Washing Machine Water Inlet Valve 285805
May 23, 2016 | Whirlpool Washing Machines
Our Roper Top Loading Washing Machine won't fill with cold water and the machine makes a electrical buzzing noise when you turn it on set to Cold/Cold.
Lift the top of your washing machine by unscrewing the back or remove the back and you will find a code and test sheet inside, you normally will find it at the top edge of the machine from or back. Very easy to use if followed to a T.
Jan 20, 2016 | Roper Washing Machines
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Wash machine will fill with water when set on rinse but not to start a load
if you have a warm wash setting you are using, and a cold rinse setting, it's possible the solenoid on the hot side of the water inlet valve if burned out. try to fill the machine with cold water only and see if it will fill.
Oct 11, 2009 | Kenmore 20722
Will not fill or rinse on the cold water setting
sounds like faulty fill solonoid valve,,you can check it with multimeter if your handy...
Oct 03, 2009 | Washing Machines
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
