Question about HP Office Equipment & Supplies
My printer HP PCS 1400 All-in.one The E sign stays on the printer is loaded with A4 paper and I keep getting print cartridge error.
  • 2,427 Answers
Remove the print cartridge and relpace it,, It its a new cartridge then ensure its genuine.
You may also want to clean the cartridge contacts with some alcohol or menthylated spirit ,, as well as the metal contacts in the ink well (the thing the cartridge plugs into) if that fails then you printer needs servicing as the wate ink tank may be full contact Hp for you closest agent
Posted on Jul 17, 2008
    Genius:
  • 3,422 Answers
Please CLICK HERE and follow the troubleshooting steps mentioned and your problem will be solved.
  • Priya darshan Jul 17, 2008
    Please don't forget to accept the solution.
  • HP Master
  • 13,433 Answers
E sign on the printer lcd? Can you be more spesific as to what else the display is showing then E, e and a error code?
Thanks.
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
Cp305d paper size error
It may be a sensor problem When you reseat the tray it may not be actuating the paper size switches correctly. Check the paper tray and make sure that there aren't any missing or broken/bent tabs on it.
Mar 17, 2014 | Office Equipment & Supplies
The print head needs cleaning
  1. Make sure letter, A4, or legal sized, unused white paper is loaded in the main tray.
  2. Press the Setup button (c01361401.gif ) on the control panel of the product.
  3. Press the right arrow button (c01185072.jpg ) to select Tools , and then press OK .
  4. Press the right arrow button (c01185072.jpg ) to select Clean Cartridge , and then press OK .
  5. The product prints a page that can be recycled or discarded.
Method two: Clean the print cartridges using HP Solution Center To clean the print cartridges using the HP Solution Center, use the following steps.
  2. From the HP Solution Center, click Settings , and then click Printer Toolbox .
  3. Click the Device Services tab, and then click Clean the Print Cartridges .
  4. Follow the onscreen instructions until you are satisfied with the quality of the printed output, and then click Done .
Other solutions customers found helpful » HP Officejet J4500/J4600 All-in-One Series -- Aligning Cartridges
Oct 28, 2010 | HP Photosmart C4580 All-in-One InkJet...
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
Dec 01, 2009 | HP PSC 950 All-In-One InkJet Printer
Hp 56 cartridge prints perfectly but keeps indicating problem
This is a common problem with compatible cartridges where the chip on the cartridge is faulty, missing or is not making contact correctly with the printer cartridge connectors. The first thing to do is make sure that the plastic seal has been removed from the chip and that it is free of any residual adhesive etc. You can clean this with a cotton bud soaked in isopropyl alcohol or VCR tape head cleaner. DO NOT USE SURGICAL SPIRIT or any other cleanser as this will either leave a residue itself or damage the plastics and rubbers in the printer.
Once cleaned reinsert the cartridge and try again. If this is still unsuccessful the best solution is to return the cartridges to the vendor where you bought them and get another brand of cartridges or use genuine original cartridges. When you find a reliable manufacturer of cartridges, stay with them. Don’t forget to clean the print head and realign & recalibrate the printer at every cartridge change for optimum results. Also make sure that you use high quality paper for the best images results.
If you have colour or photo paper loaded in the Main tray when you align the printer, the alignment might fail. Load unused plain white letter or A4 paper into the Main tray, and then try the alignment again. If the alignment fails again, you might have a defective sensor or ink cartridge.
Oct 03, 2009 | HP DeskJet 5650 InkJet Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printer will not print after reinstall of software to macbook
yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
to determine the status of the ink..
goto your desktop ..
click the printer driver software and select ink status..
good luck.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
I can not print and the empty sign stays on my printer when still loaded A4 paper. I keep getting PRINT CARTRIDGE ERROR on my PC. My printer HP PSC 1400
is the Print Cartridge in right place? I think you should contact HP service. It can help to change the cartridge.
Jul 17, 2008 | HP Office Equipment & Supplies
How to change cartridgeon HP desktop D4160
from HP's web site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00641960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Step one: Replace the old print cartridge
  1. Make sure the product is turned on.
  2. Open the print carriage access door.
  3. Wait until the print carriage moves to the right side of product and is idle and silent.
  4. Press down on the print cartridge to remove it from the slot, and then slide it out of the print carriage.
  5. Remove the new print cartridge from its packaging, and then carefully remove the plastic tape by using the pink pull tab. Figure 1: Remove the tape c00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  6. Slide the print cartridge at a slight upward angle into the print carriage until it snaps into place. Figure 2: Inserting the print cartridge c00642241.gif
  7. Close the print carriage access door. WARNING: Keep both new and used print cartridges out of the reach of children.
  8. Wait until the print carriage moves to the right side of the product and is idle and silent.
Step two: Align the new print cartridge
  1. Load Letter or A4 size, unused, plain, white paper in the input tray.
  2. Open the printer Toolbox . Follow these steps to open the printer Toolbox .
    1. From the File menu in the software program, click Print . The Print dialog box appears.
    2. Click the Properties button. The Print Properties dialog box appears.
    3. Click the Features tab.
    4. Click Printer services . The printer Toolbox appears.
  3. Click Align the Print Cartridges .
  4. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and then calibrates the product. Recycle or discard the test page.
Dec 23, 2007 | HP 83 3-ink Black UV Cartridge Multipack...
60 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
