Question about Apple iPod nano
Ipod nano middle botton won't work
The middle botton just won't work i've trid everything and it won't work
  • 1 more comment
  • Anonymous Jul 19, 2008
    nano stuck on welcome screen
  • Anonymous Oct 07, 2008
    my middle button wont work. i cant get to my song list and select a song. it wont even reset.
  • singinfemale Oct 14, 2008
    if i press play the song comes up but when i press menu and then try to pick a dif song, the middle button wont work. ever.
  • 31 Answers
Try reseting your ipod
Toggle to hold switch on then off.
Press and hold both the menu and middle button until the screen goes blank.
The apple logo should then appear on startup.
If this fails then you need to replace the touch wheel.
Posted on Jul 23, 2008
Pls give me any trick to update my ipod nano a1236 2g version
You should connect your nano to pc. Open iTunes, and in ipod window press "Check for update" button.
Apr 10, 2011 | Apple iPod nano
How do I delete videos I MADE from my iPod?
Press on the middle big botton when you see the vid and it will say delete and click it worked for me hopes it does for you
Dec 30, 2009 | Apple iPod nano
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
My ipod screen is blank!! HELP!!!
First try to reset it, do this by holding down the "Menu" button and the middle button for about 7-8 seconds. If it still doesn't work, try restoring it. Plug it into your computer and open iTunes. Now select your iPod in the list to the left, then click the button that says "Restore," it`s located right under the picture of your iPod model.
Hope this helps!
Sep 03, 2009 | Apple iPod nano 3rd Generation
My ipod is displaying sychronizing and it wont turn off and none of the buttons work
try a hard reset. switch the lock botton from off to on and off again, then hold down the middle button and top button. it should then restart
Aug 18, 2009 | Apple iPod nano
My iPod nano says enter code
If you dont know the password.. or if you didn't enter one then go ahead and connect the ipod to compute rand then update the software using itunes ... if this doen't work then try to restore the ipod to factory settings which will erase everything from ipod and then sync with itunes again..
pls reply
Jan 22, 2009 | Apple iPod nano
IPod Nano 3rd Gen...click wheel seems to be frozen....
Hi, First find whether the Hold switch is in off hold position... ( Hold switch can be found at the botton or on the top of ipod) then try:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jan 13, 2009 | Apple iPod nano
Ipod Nano 8gb won´t synchronize
Try this.
  1. Put the iPod into disk mode by holding the menu and middle keys together until the screen turns dark.
  2. Then quickly hold both he middle button and play/pause buttons until the iPod shows a check mark and the words disk mode at the top.
  3. ThenClick on iTunes to open it.
  4. Connect the iPod to the computer. You may have to do a restore depending on what iTunes says you need to do.
If this doesn't work, check the bottom of the ipod where you connect the cable. See if there are any bent pins. These are very fragile and can be damaged if you insert or pull the cable out the wrong way. Hope that helps.
Dec 19, 2008 | Apple iPod nano
My ipod screen stays white, cant read it
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore http://www.apple.com/support/ipod.five_rs/
If you need more asistance, let me know. Good luck.
Feb 26, 2008 | Apple iPod nano
Apple IPOD froze up
reset it by pressing the middle botton and menu at the same time
Jan 19, 2008 | Apple iPod nano
Apple iPod nano Logo
399 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
