Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator getting hot!
The post between the doors is getting hot.  Almost to the point of not being able to touch it! What up Jeff
  • knight5517 Aug 03, 2008
    have the same proplem
    did u find a solution?
  • Lee2fixit May 11, 2010
    Is it staying hot continuously? Is the inside wall of the freezer also warmer than usual? Wondering if the defroster might be staying on all the time.
  • 218 Answers
Perhaps you've got the problem fixed by now, but just for the sake of tying up loose ends... Did you check for airflow under the refrigerator? The symptoms you described sound like the condenser fan is not blowing air across the condenser coils to take away the heat. You might have a bad condenser fan motor. Also clean out any accumulated dust under there.
Posted on Jul 25, 2008
Just the front of the center post. There is also alot of heat coming from behind the unit.
thanks
jeff
Posted on Jul 17, 2008
Seals on my beco are hot to touch fridge freezer feel warm
Almost the same post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
Post between freezer and refrigerator doors is hot
I have seen a programme on TV which showed a cable between the doors which over time with constant opening and closing became worn. I should contact the manufacturer.
Apr 21, 2012 | Samsung RS2630SH Side by Side Refrigerator
Hot around both doors where mangets touch, very hot to touch
some heat at this point is normal but if too hot ck the cond coil and clean it and make sure the fans are cooling the coil .. mm
Sep 01, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have water to the water line and it comes out the water dispenser, but I get no Ice from the maker and it doesn't make any ice at all. this is a hot point refrigerator freezer with the ice maker on the...
Hi: No.1 it takes 24 to 72 hours for the machine to make ice. No. 2, If the freezer is not at zero degrees it will not make ice. I'm not talking frozen but zero F. Ice cream will be rock hard. These icemakers are thermally proctected as not to dump unfrozen ice in the tray. I hope this helps, Jeff
Jun 21, 2009 | Refrigerators
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
539 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
