Poor voice reception on headset/microphone - Audio Players & Recorders
I found a loose coneation on the 2.5 jack that plugs into the phone
Posted on Jul 17, 2008
I hear my own voice when I talk on Logitecs H600 wireless headset
IF you are in Windows 7: -
1. Click "Control Panel" > "Sound" > "Recording"
2. Place cursor over "Microphone - Logitech Wireless Headset Default Device".
3. Right Click and select "Properties"
4. Click the "Listen" Tab
5. Uncheck the "Listen to this device"
6. Click "Apply",. and "OK"
That will eliminate you hearing any nose picked up by the microphone. Others will still be able to hear your voice as long as you have the headset as your default microphone.
Mar 02, 2013 | Logitech (980408) Wireless Headset
I have a Plantronics C610 headset. The caller can hear me, but I can not hear the caller.
Here are a couple of things you can try. I included the link for the user guide below.
Callers cannot hear me.
• Headset is muted. Press the mute button on headset to unmute the microphone.
• Headset microphone boom aligned incorrectly. Align the headset boom with your mouth.
• The USB adapter is not set as the default Voice device. Use the Voice settings in Windows under Sounds and Voice Devices to select "Plantronics C610/C620" as the voice device.
Here is a link to the Plantronics C610 User's Guide.
Good luck from Headsets Direct!
Jun 16, 2011 | Plantronics Blackwire C610 Headset
I have a Plantronics monoaural headset Audio 310 which is failing to give me a strong microphone signal - going through Control Panel (Sounds and Audio Devices - testing). I am using a voice to text...
Disconnect the microphone from the headset and connect another microphone to eliminate the possibility that it's bad. If the other microphone has the same symptom, then adjust the the sensitivity of the mic through the sound card properties. Or, try another sound card - it may be bad.
Feb 23, 2011 | Plantronics .Audio 310 Headset
Can someone tell me step by step, where is the microphone located on the Hanspree 20" flat panel LCD monitor? I can't find any info in the manual on this. I go on to Skype and my speakers work but not the...
Hannspree says they don't offer a 19" LCD with a built-in microphone. If there is one, I can't suggest you use it as noone would be able to understand you well.Their built-in speakers,also, are notorious for low power and poor, tinny sound. the addition of a USB or audio card compatible type headset is recommended for most voice applications, including Skype. Tigerdirect.com, overstock.com or walmart.com all have inexpensive headsets and stand alone mikes. Hope this helps some:)
Aug 20, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
My motoriola H710 headset is paired, but no one can hear me
The microphone no longer works. Don’t know if you can change the Microphone of your headset through some authorized service personnel or not.
Jun 04, 2010 | Motorola Mobility H710 Bluetooth Headset
Hearin myself in just one side of the headset!! help
Make sure when you create a new track in your software, you are creating a Mono track, not a Stereo track.
Create a Mono channel and choose a single channel.
Mar 23, 2010 | Portacom Porta-Com COM-60FC 6 Headset...
Poor sound quality via Bluetooth mic after switch to iPhone 3GS
Unfortunately, solution is NOT free. Until Apple decides to take good look into this issue, you are left to buying another BT headset model.
I got lucky first time around, bought new Plantronics (not Playtronics...) Voyager 520 (I do love Plantronics 3xx design, this is the next best thing). It did cost almost twice as much as my previous headsets (about 45 EUR), but it's still on the cheap "side" and (to my experience) also the best value.
Hope new headset also lasts almost whole week before needing recharge, like my "old ones". :)
Aug 26, 2009 | Apple iPhone 3G
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Garmin Zumo wired headset
I bought a wired motorcycle headset, which does works okay (below 50 mph) www.imc-motorcom.com, didn't like the wire so I switched to a BT helmet kit, manufactured by interphone, works like a charm.
May 03, 2008 | Garmin zumo 550 GPS Receiver
Poor FM reception
The Phone must be on.
The SIM card must be a valid one.
The station you listen to and the network operator you use, must support the service.
The headset or enhancement needs to be attached to your phone. for the FM radio to function properly, it's an aerial as well as a headset.
Therefor if you are in a poor reception area for making/receiving calls it will also affect the radio signal.
Jan 13, 2008 | Nokia N73 Cellular Phone
 Grubhead
Grubhead
