Question about Durabrand STS92 System
Help i got this 2 weeks ago and rented cd stuck
Put the rented cd in the dvd slot closed the try, now it wont open, or shut off any suggestions?
    Champion:
  • 224 Answers
Most players have a small hole just below the tray (a little bigger than a pin hole),put a pin in the hole,and the tray should open.
Posted on Jul 17, 2008
LG cd-rom crd 8482b Doesnt Read Dvd's
well if its new i would say return it, if not then i would suggest to use canned air and blow out the inside of it and try it again. if that don't work then i would recommend getting a new one.
Dec 04, 2009 | Computers & Internet
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. djmax1966@yahoo.com..
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
Toshiba laptop stuck
try to use the restore cd.. .. select boot from the cd/dvd and boot the repair features with the OS
look at the boot screen that initially shows up and get in the setup.... switch the cd/dvd to be the boot device that starts first...
run the cd/dvd installation normally until you find a repair feature.....
then follow the standard repair method
Sep 30, 2009 | Computers & Internet
My cd/dvd port slot keeps getting stuck.
Lubricate it. Otherwise change it for a brand new unit for $15-25 only. Now they are cheap as dirt. & it will last for 5 more years.
Sep 19, 2009 | Tascam (CDRW900)
My cd/dvd drawer open or close. was stuck open. now has closed an
You may force eject the CD tray by inserting a paper clip inside the small slot or you may force restart your computer by pressing the power button for 5 seconds.
Jun 10, 2009 | Microsoft Windows Vista Ultimate Edition
Shuts off after inserting disc
This unit has a problem with component failure in the dvd section of the unit. It is probably in the power supply to the dvd drive. Thats why it fails when you insert a dvd. You should get the unit tested and serviced for the problem. You can call the Magnavox customer support at thsi telephone number 1-800-605-8453. Tell them the model number of the unit and about the failure of dvd section of the unit. They will be able to tell you how you can get the unit serviced. I hope this information helps you with you problem.
May 23, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Disk wont eject
tough luck buddy, this system is sh!t. i'm on my second and have now got a similar problem with the second system. I eventually took a pen knife to the first unit to get the dvd out and then managed to get a rented dvd stuck in the machine a week later.
Aug 17, 2008 | Philips HTS-6500/37 System
CD player eject mechanism problem
cant put cd in pulled out know its stuck closed so you cant insert cd.
May 29, 2008 | Audio Players & Recorders
HP DVD WRITER 840b - CD/DVD Tray won't open??!!
Problem of tray opening on hp dvd burner. I got the door open as suggested above with paperclip. Then took some CRC 2-26 plastic safe electrical grade lubricant and swabbed the pivoting door mechanism. Opened with the paperclip about 5-6 more times until it finally opens normally.
Feb 28, 2008 | HP (176135-630) (176135630) Internal 48x...
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Durabrand STS92 System Logo
76 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
