Toastmaster TBR2 Bread Maker Logo
Brian Ford Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Toastmaster TBR2 bread machine does not knead when started. It makes a tick-tock noise and the timer counts down but no mixing. The bread pan is positioned correctly. Why?
  • Daryl Nash
    Daryl Nash Jan 22, 2011
    how long did you let it sit while it did nothing but click?
Lance Hill
Level 3:
Genius:
  • Master 1,739 Answers
  • Posted on Mar 01, 2011
Lance Hill
Master
Level 3:
Genius:
Answers
1739
Questions
Helped
800600
Points
4235
Make sure you are programming your machine correctly.
The Instruction Manual indicates three possible problems, none of which would seem to be your problem. Not plugged in, error message or kneading blade missing.
Suggest you review the Instruction Manual for programming your bread maker. Unplug your machine to reset and then plug in and program as directed.
TRB2 Instruction Manual:
http://dl.owneriq.net/4/4ae504be-4834-4845-a8f8-7a6df62c1033.pdf
Welbilt bread machine kneading wont start.making ticking sound
some bread machines warm the ingredients before any mixing starts. If your breamachine doesn't start mixing within 1/2 hour then you DO have a problem. Give it a half hour before you assume it is broken.
2helpful
I need a replacement kneading blade for my TBR15 toastmaster breadmaker. How can I order one?
You could buy it from :-
http://cgi.ebay.com/Toastmaster-TBR15-TBR2-PADDLE-Bread-Machine-Blade-NEW-/310145056299?pt=Small_Kitchen_Appliances_US&hash=item483615fe2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Model TBR2 i NEED TO KNOW HOW TO START MY
  1. I have lost my Toastmaster Bread Box Manuel
How can I obtain one??
Teresa Anderson
[email protected]
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
1helpful
Bread pan bearing on my Toastmaster TBR2 is binding. How do I clean/lubricate it?
That is a sealed bearing and can't be lubricated. Eventually that sealed bearing gets worn out and then breaks. The bread pan will then need to be replaced...Sorry Hank
3helpful
I need a kneading paddle for TBR2!
A Google search turned up these folks. Looks like they have your paddle.
http://abtecparts.com/toastmaster_breadmaker_paddles.htm
Top Toastmaster Kitchen Appliances - Others Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
