Question about Mitsubishi WS-65809 65" Rear Projection Television
Error Codes I have the Mitsubishi WS 65809. It shuts off by itself at times and then won't power up for a while.. We did the error code buttons and got SQV2 on the screen.. We aren't sure if that is the error code or not.. It won't leave the screen now.. What could be the problem and is it an expensive fix???
  • Mitsubishi Master
  • 8,617 Answers
SQV is a setting under the Channel edit function in the setup menu. Your model doesnt have the on screen error. What you do is next time it shuts down you have to press input and menu on the sets front panel both in together for 5 seconds to see if the LED will blink a two digit error code.
Posted on Jul 17, 2008
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi model ws-65809. i press the power button the green light comes on then it shuts back off.
IF YOU have unplugged it plug it back and try to turn it on, when green power light goes out:
On the front of the set press and hold BOTH the menu and input buttons at the same time--hold both for at least 5 seconds and release both.
This is the self check this set has: power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
The 2,2 error code is the most common and is short protection and I know if that code how to fix the set---for many customers it can be a do it yourself fix with parts cost under 35 dollars total.
Let me know what code you get and I will try to help you.
Fixed over 1,000 of these Mitsubishi sets.
SD TECH
Mar 24, 2012 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi ws-65809, the tv won't power
I presume you unplugged the set and redid the check:
2,3 is deflection circuit problem (probably in Horizontal sweep circuit) and can be almost anything---check output transistors and look for cracked or bad cap in that area.
The error code is only a general indication of the kind of problem and this one is like saying car will not start etc.
Mar 18, 2012 | Mitsubishi Televison & Video
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
The Light turns on and then 2-3 seconds later turns off. Any solutions to fix it?
DO SELF CHECK IT HAS: WHEN SHUTS OFF PRESS AND HOLD BOTH THE MENU AND INPUT BUTTONS ON THE FRONT OF THE SET FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
POWER LIGHT WILL BLINK TWO DIGIT ERROR CODE LIKE: 2 blinks, 2 blinks, a pause and repeat 4 more times.
let me know error code found and I will tell you what it means.
SD TECH
Aug 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
TV TURNS ITSELF OFF
If the WS-65809 comes on and then the power light goes off---do the self check this model has:
When the light goes off on the power button----on the front of the TV press both the MENU and INPUT (or device) buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code--for example--2 blinks, a pause and 2 blinks--this is the most common error code and costs the least to fix.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 16, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Will not turn on, 3 seconds after pushing power button turns off again. Thanks!
Engage the self diagnostic feature that this set has:
after set shuts off; On front of set push and hold both the Menu and Input buttons in together for 5 seconds and release both buttons.
The power light should blink a two digit error code (it will repeat it about 10 times) for example: two blinks, a pause, and two blinks (this is the most common error code)
Let me know what the error code is and I will tell you what it means
SD TECH
Sep 29, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
The error codes...
a 2 3 code means horizontal deflection has stopped thats what is most likely shutting down your set. The most probable cause for this would be a defective Horizontal output transistor.
Jul 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
