Have Westinghouse 32"LCD TV. When its very hot and humid after being on for approximately 30 minutes black, heavy vertical wavey lines appear on the screen. Sometimers I can make the lines disappear by cycling the set off and on, but the lines come back. The lines do go away after the A/C cools off the room
  • 3 Answers
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Posted on May 14, 2009
Why is it that my westinghouse 32 in LEDTV model#LD-3265 just went blank on me no sound no picture but powered up properly
Do the menus work or input labels appear when you change sources?
Have you tried unplugging the power with the tv turned on, waiting a few minutes, then plugging it back in and turning it on?
Jul 14, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Screen went black with a couple vertical colored lines
Check the tcons connections ( both flex cables and also the LVDS cable) if that doesnt solve it would suspect the Tcon as being defective. For further assistance please respond to this same post.
Jan 01, 2013 | Westinghouse 32" Flat Panel LCD HDTV
TX-52F480S lines
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Oct 11, 2012 | Westinghouse TX-52F480S 52 in. LCD TV
Westinghouse ld-3235 picture goes in and out connections are good stops after 30 minutes or so,only 5 wks old
I have the same tv and had the same problem.
If picture appears when you slowly hit back of the tv, then the solution is quite easy.
1-There are 2 small lids on the back of the tv, open the one at the top with using a screw driver.
2- there is a connector on the top, make sure that it is connected well.
As far as I understand there is somehow a connection problem or maybe result of oxidation or something.... 5_3_2012_9_06_22_pm.jpg5_3_2012_9_06_40_pm.jpg5_3_2012_9_06_54_pm.jpg
Oct 09, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Black vertical lines on samsung lcd tv.when powered on the black vertical line appears in the middle
Vertical lines are usually a a sign that your T-con board is going bad. You can get replacement parts for this TV at www.interliquidparts.com
Sep 27, 2011 | Samsung LN32A330 32 in. LCD TV
About 8 months ago, every time I turned on the TV (SK-26H590D), only vertical lines would appears... almost like watercolor: green, orange, etc. However, you could hear the channels and change them as...
Hello
Get into Menu Operations and come to the window video reset. You can get this in its manual section [1-6]. Reset all video sub menu items to factory reset. Check out after this reset process whether the problem solves or not. If not its video card has some trouble. Contact
www.westinghousedigital.com and enquire them about the nearest westinghouse Authorised Service center of theirs to you. Thy only can set it right. OK.
May 08, 2011 | Westinghouse SK-26H590D Television
Westinghouse 32" LCD TV
It seems your pixelsare burning out. contact the NY Service Center for Westinghouse. web is www.asnyonine.com
Jun 24, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
White Westinghouse 32 in Issue
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
Mar 03, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 32" LCD - Vertical Line across top of picture
i had this same problem, it ended up being a loose connection on mine, attached picture is where the connection was loose, i took off the back panel and just reattached it, and it was good as new.e87b8ee.jpg
Nov 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
