Question about Safa Q100 MP3 Player
When i wamt to sync my goodmans mp3 on windows media player it wont pick up the device
MP3 is not syncing
try pressing the reset button on the back you may need a pin or tooth pick because it is very small it should work then
Apr 22, 2010 | Philips GoGear Ariaz MP3 Player
SONY BEAN WONT SYNC MUSIC WITH ITS SONIC STAGE SOFTWARE. with what software can i sync music on this mp3 player
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 30, 2009 | Sony Bean MP3 Player
My MP3 player won't connect to my laptop
Open up your windows media player on your computer and select the sync tab on the upper righthand side .Plug In your MP3 Player and now It should be recognized there on the right pane window when you use the sync feature on windows media player !! Drag your music files from your library to this area and they should sync to your player using the button in the lower right hand corner area . I believe it will say sync or sync device !! Rock and Roll Swampratt200 AAAAEEE!!!!!!!
Jul 05, 2009 | Samsung YP-K5 MP3 Player
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Sep 11, 2008 | Philips GoGear HDD1830 MP3 Player
My media player 11 won't show up on my computer? it was working fine but now it wont show up
Read the warning about this device and Windows Media Player 11 at www.usasupport.philips.com
You will need to reformat the GoGear in Windows Media Player, but do a firmware upgrade first - open the Philips Device Manager and click on the Update tab. Then click the update button. After the firmware upgrade is done, open windows Media Player.
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your GoGear to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Philips Go Gear SAXXX" (wording may vary slightly), and then select "Format." - this should erase everything, and make your player properly read in Windows Media Player.
-Tha Mp3 Doctor
Mar 21, 2008 | Philips GoGear HDD1830 MP3 Player
Help blonde in need
OK blondjoke windows vista doesn't work on a lot of things but here is a fast and easy way to fix it. Plug your MP3 into the computer it will show up on "My Computer" as a driver. Then go to Windows Media Player pick the music you wish to play on your mp3, next go to Sync chose device driver your MP3 then drag the music you have picked out to the Sync box then click Sync this will download your music to your MP3. do not forget your microsd card you can download on and use to.
DGW
Dec 25, 2007 | RCA TH1101 MP3 Player
HELPP MEE! :)
Ok people let us try a little help here. the cd you are trying to load may not work but let us plug in our MP3 players and go to My Computer and see if it comes up as another ubs drive in most cases it does. In this case I tell the person go to windows media player pick the music they want in their player and click sync. At that click click device drive this is where you put the drive where your MP3 is located on the Windows media Player then click sync and it should download your music
Dec 22, 2007 | RCA TH1101 MP3 Player
Problem playing music files with new Goodmans mp3 player (GMP34G5)
i got mine about an hour ago and it works fine. don't drag and drop music files, sync them to the mp3 player using windows media player.
Dec 02, 2007 | GPX ML848B Digital Media Player
How do i put photos on?
There is a folder that can be seen in Explorer. For example:
My Computer\Philips HDD63XX GoGear\Media\Pictures
But transferring files this way is futile. There's something about the media player 10 sync process that updates a database on the mp3 player. Media Player 11 doesn't seem to do this correctly. Philips needs to resolve this as new machines are not shipping with version 10 anymore.
Aug 27, 2007 | Philips GoGear HDD6330 MP3 Player
WINDOWS MEDIA PLAYER WONT DETECT DEVICE
i had a similar problem (would not load driver) and was able to solve with the following: 1. install version 10 or greater of windows media player. 2. in Device Manager (hardware tab on System in Control Panel) right click the ? Samsung YP-T7J and pick update driver 3. Select No, not this time, Next> 4. Install from a list...., Next> 5. Don't search, I will choose.., Next> 6. Select Portable Devices, Next> 7. Select MTP Device, Next> 8. The drivers are copied and the device is recognized. There are other prompts depending on your media player config, but only pertains to how the device is handled. jlw.
Dec 19, 2006 | Samsung Yepp YP-T7JX MP3 Player
Safa Q100 MP3 Player Logo
76 people viewed this question
Top Safa Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Safa Audio Player and Recorder Expert? Answer questions, earn points and help others
