Question about Apple iPhone Smartphone
Iphone can't receive calls
Hi, my iphone doesn't ring/vibrate for incoming calls, it goes straight to voicemail. I checked to make sure it's not on mute. the only way i know i had calls is if the caller leaves a voicemail message. it beeps to notify me that i have a voicemail message. please help....i use this phone for business.
  • Anonymous Dec 22, 2008
    I have the exact same problem. the phone doesnt even respond to a recieved call and it goes straight to voicemail. how can i fix this?!?! it says the call forwarding option is off so I really dont know what the problem is.
  • Anonymous Mar 29, 2014
    I have iphone that I just changed to straight talk I can receive phone calls but no internet
    Sergeant:
  • 196 Answers
Check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Posted on Sep 07, 2008
    Problem Solver:
  • 6 Answers
Menu > Call Logs > Menu button > Options > Call forwarding
Posted on Jan 23, 2012
Calls to my new mobile are going straight to voicemail
When your iPhone is locked (the screen is off), Do Not Disturb silences all incoming calls, text message notifications, and alerts on your iPhone. Unlike silent mode, Do Not Disturb sends incoming calls straight to voicemail. Disable do not disturb
Nov 26, 2016 | Cell Phones
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
For incoming calls... my iphone goes straight to voicemail... It will not ring through
Go to "settings" icon, lick on it scroll to "do not disturb" click on that and make sure you have all turned off.
Hioe or this helps.
Es
Jun 12, 2014 | Apple iPhone Smartphone
I cannot receive any incoming calls
power down, take battery out for a complete 2 minutes. While battery is out hold the power button. this decharges built up static electricty. After 2 minutes reinstall battery and power on phone. If it doesn't work call your provider they will walk you through a series of steps to hardset your phone.
Feb 12, 2012 | RIM BlackBerry Curve 8520 Smartphone
Hi I have a Panasonic cordless phone kx tg2511al. I sometimes find that incoming calls go straight to voicemail without it ringing first. How do I make sure it rings at least a good number of times...
Remove the battery and allow the set to phone to reset. Now check for the ringer setting at teh back of the base phone to be set to the maximum rings, there can be three settings.
Some times this is also set on the menu.
Connect and test the timing to confirm
Jun 13, 2011 | Cell Phones
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
IPhone doesn't receive calls
just found this on the internet...
Toggle airplane mode: Tap Settings > Enable Airplane Mode, wait five seconds, then turn off airplane mode. Check your phone settings: Check your Do Not Disturb settings: Tap Settings > Do Not Disturb. ... See if Call Forwarding is turned on: Tap Settings > Phone > Call Forwarding.12 Nov 2013
I am not receiving incoming calls on my iPhone ... ' Official ...
https://discussions.apple.com/thread/5552399?tstart=0..
or try this link..
IPhone doesn receive calls Google Search
Oct 27, 2017 | Apple iPhone Smartphone
Incoming calls
i would got into your voicemail settings and check to see if you have it set to ring once then straight to vmail.. i'm not sure how your phone is set up completely but i would assume you can adjust the amount of rings before vmail picks up.. is this phone new to you?
hope this helps..
d
Feb 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Feb 19, 2008 | RIM BlackBerry 8800 Smartphone
INCOMING CALLS
upgrade the phone to WM6 with A3.5 @ ppcgeeks.com --> apache forums.
that will upgrade the phone's firmware at the same time as upgrading the ROM to WM6
Aug 02, 2007 | Audiovox PPC 6700
Apple iPhone Smartphone Logo
4,139 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
