Question about ASUS C90S Notebook
C90 thinking about buying new video card
Power is fine laptop runs can hear it powering up, but screen does not turn on? I think its the video card that blew, would replacing it fix this? Does not display, not even hooked to a secondary moniter.
  • raul55 Jul 17, 2008
    Its a ASUS C90 laptop know as a upgradable laptop, taking out the card was an ease, is there still going to be a problem with motherbord if replaced?
    Thanks, good idea I guess im out of luck I bought the laptop off a friend.. I ll send it out and hopefully the service charge do not outwiegh the value of the laptop.
    Thanks again!
  • 2,794 Answers
Most video cards are integrated into the motherboard of the laptop.
You would have to replace that whole motherboard.
Posted on Jul 17, 2008
  • Tim Babcock
    Tim Babcock Jul 17, 2008
    Thats a good idea to be able to upgrade them. The only problem is some of these video cards are drawing a lot of heat and the battery right along with it. I wonder if they stop supporting them because there were a few too many computers getting cooked.
    It shouldn't be hard to get a motherboard from Asus. You might have to contact support to get one because support on their website for notebook computers is pretty sparse.
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
Hi, I have a Lenovo laptop computer. The model is Lenove 3000 N200 0769 A8U. Recently it has a problem with the display. When I power on the computer, there is no display at all, just a horizontal bright...
I would say your laptop is fine it is a display you require.
If you browse ebay there are lots to choose from at different prices. It is a straightforward job to replace the screen.
Hope this helps.
Dec 30, 2010 | Lenovo 0769AFU 3000 N200 0769-AFU Notebook...
When I try to turn the laptop on, it comes on for approx 1 second and turns off. The indicator lights flash and you hear a noise from the cdrom. No display on the screen, no beeps. It does this when...
It looks like it's one of the following: a) fan not running and CPU overheating; b) video card fried; c) CPU fried
Possible solutions:
a) Check to see if you can hear the fan running when you turn it on. It should run all the time, sometimes fast, sometimes slow, but ALWAYS on. Check if the laptop has too much dust inside it and clean it up (remove the bottom cover and blow air using a compressed air can). If the fan runs ok and is always running, then go to the next point
b) if the video card is fried, there is nothing you can do. Video cards in laptops are usually part of the motherboard and is not something that can be replaced or repaired. You'll need a new montherboard... and it is more convenient to replace the whole laptop. Sell your old one for parts.
c) Same as above. If the CPU is fried, it can't be replaced or repaired. Get a new laptop.
Mar 15, 2010 | Sony VAIO VGN-B100B Notebook
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
The screen automatically turns off even though the laptop is on..
First i need to know if the screen comes back on if you move your mouse. Because if it does the update changed your settings for power saving. To change this, either check the screen saver setting to make sure that is not on blank screen and if that is not the case go to Start Menu>Control Panel>Power Options and see what the settings under power schemes is. It will have two options, Plugged in and batteries. For plugged in Set the time To never and it won't turn your display off on you again.
If this doesn't work let me know so i can update and solve your problem
Hope This Helps
Nov 20, 2008 | Dell Latitude D630 Notebook
Dell inspiration 1150 laptop
sounds like screen is blew out try rebooting it with orther screen get back to me lala linda
Apr 25, 2008 | Dell Inspiron 1150 Notebook
ASUS C90S Notebook Logo
265 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
