Question about Electrolux Vacuums
I have a Harmony vacuum that's a couple years old. I recently sucked a fair amount of dog hair into it and was unaware something was amiss since the things so quiet. It just shut down and wouldn't come back on. 10 minutes or so later it came back on but now it's got no sucking power. I figure I torched the motor. Good guess? What are my options--I'm out in the middle of no where but can get it to a repair shop 250 miles away. Is it worth trying to salvage or am I going to pay as much to get it fixed as to **** it up and buy another?
I cleaned the whole thing out, changed out all the filters again and cleaned out the motor compartment. Then I discovered a huge clog in the line. Once I got that all done--it's now working like a charm. Moral of the story: spend more time looking for the little things before jumping the gun and assuming it's a major problem. Thanks for walking me through the process!
Posted on Jul 17, 2008
  • 30 Answers
Hi There,
Nope, I don't think you torched the motor. I believe this model has a thermal cut-out on the motor that prevents this. I am pretty sure that the vacuum is blocked somewhere, you see, the air that is sucked in is the same air that cools the motor. When the vacuum is blocked, the cooling stops, motor overheats and the thermal trip jumps in. Ten mins later, the trip kicks out (as the motor cools) and away you go, but until the blockage is cleared it will keep doing this. The blockage could be anywhere right up to the turbine on the motor itself so, unplug it, get the screwdriver out and get going. Start with all external hoses\channels before tackling internals using a long piece of dowel or similar poking thingy.
One final note, you may well find that the pet hair managed to block the system by getting stuck on some other object that was already there (usually something silly like a toothpick) pet hair doesn't usually block vacuums on its own. Make sure you clear everything out or the problem will re-occur.
Hope this helps.
Kind Regards......Dave
Why is my dyson dc54 blowing instead of sucking?
Congrats! See the comments for the solution.
Sep 13, 2016 | Dyson Vacuums
What could make the vacuum cleaner suction stop sucking
Usually that happens when the sweeper is plugged up inside. Dog hair, cat hair and the vacuum fresh will build up in there over time and kill your suction. hope this helps
Nov 08, 2013 | Vacuums
What's the best vacuum for pet hair?
Try a bagless vacuum cleaner as hair blocks up bags very quickly. One that is around 2000 watts should have enough power to do the job. As for the price check appliance stores for sales and deals.
May 31, 2013 | Vacuums
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Vacuum throws dirt onto machine and not in it
Hi its Darran at Dyson.
It sounds as though your machine is blocked. This is why the dirt is being dropped back out on your floor and also why the bin is not filling up.
Simply follow the blockage procedure in your user guide, or on our website at www.dyson.com. Visit the support section and you will be able to download a user guide. This will also allow you to confirm if the machine is correctly assembled and that there are no parts missing on disconnected.
Kind regards
Darran
Dyson Customer Service
Mar 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I believe it is clogged with dog hair...not sucking
Hello. Thanks for choosing Fixya! That dog hair will definitely have to be removed. Pull it out anyway you can, using a tweezer, a pair of needle nose pliers, etc. Also examine all of the hoses and remove any debris that could be adding to the problem. Regards, Joe
Nov 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction on either vac or upholstery attachment...does spray
check to see if the red lint filter in the clean dirty water tank is clean and free from fluff if this is glogged this will resticted the suction ,check to see if the tank is seated corretly
May 24, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Pro Heat 8910 clogged?
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Nov 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Lift-Off Pet Hair vacuum doesn't lift off pet hair!
very light "stuff" like dog hair will get stuck to the filter since that is where the suction goes. it's primary purpose was to keep dust out of the motor. This is a problem with many "bagless" cleaners. A bagged cleaner keeps all dirt and hair away from filters by utilizing the bag as primary filter. If you have alot of dog hair then this may have been the incorrect choice of a vac. all you can do is brush off the filter each time you use the vac. it will still pick up o.k. even when there is hair on the filter unless you leave it on day after day.
Jun 14, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dirt devil suction not as good
If the belt and filters haven't been changed in over a year, then that could be the problem. You could also have a clog in the hose.
Mar 01, 2008 | Vacuums
Vacuums Logo
62 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
