Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Jammed line spool on Ryobi gas trimmer
I can't remove the spool on my line trimmer in order to feed more line - there appears to still be remaining line on the spool, but I cannot turn the knop to align the arrows as the manual tells me to do - I suspect the line is tangled, but what can I do about it?
  • Anonymous Aug 19, 2008
    need to replace the string
  • Anonymous Sep 07, 2008
    I have the same problem. The trimmer line is tangled in the spool and there seems no way to access the internal spool assemblies. Is there a way to get into this assembly (disassemble it) to untangle the line and then reload it per user manual directions?
On my Ryobi trimmer, all I have to do is unscrew the knob (the device that you "bump" to advance the line) at the bottom of the spool and the spool can be lifted out. I had to use a strap wrench the first time since it was on very tight. You don't have to line up any arrows to remove the reel.
Posted on Sep 24, 2008
I have a microwave that arch for no reason after it has been running more than 1 minute. if I'm warming a cup of coffee it arch. if I'm popping corn it archs. Could the bulb inside of it be bado or going bad? How do I replace the bulb? if you can't help me, could you forward this to someone who can. I bought the microwave from Seaars 2-years ago.
Posted on Aug 17, 2008
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
I inherited a Ryobi 14'' Electro Hornet, but do not know how to change the trimmer line - can you help?
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Nov 29, 2009 | Ryobi Garden
How to fix my Ryobi Wipper Snipper - Model# RLT30CD? Hi, I having been using the bump feed and all of sudden its not bump feeding. What should i do about fixing this up? Cheers Clint Baird
You may have dirt in the spool, keeping the line from feeding. Or, the string is slightly tangled on the spool, not allowing it to feed properly.
Jim
Nov 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
577 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
