Question about Brother GX-6750 Typewriter
Seems like the striker key? is not hitting hard enough - have had only a few months,
Seems like the striker key is not hitting hard enough
    Sergeant:
  • 329 Answers
Spray degreaser that does not harm plastic, spray the hammer area and the this model also has a spring that brings hammer forward, could be going weak... Sounds more like sticky hammer.
Posted on Jul 21, 2008
How can I get my Wheelwriter 1000 to strike harder?
code q
Have to this everytime you turn it on and off.
Although there is a print hammer selenoid cap that fails plastic breaks and will hardly print.
Oct 29, 2015 | Office Equipment & Supplies
The striker wont hit the letter
Does the striker move forward, many times the machine needs some 3 and 1 oi in that area, not alot... just enough to free up sticky hammers.
Sep 24, 2014 | Olympia Refurbished Monica 2 Portable...
IBM Wheelwriter 6 Typewriter - while typing, characters just quit printing on paper. Checked ribbon, machine etc. Everything checked out?? What could be the problem.
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
Jan 02, 2014 | IBM Wheelwriter 6 Typewriter
My driver side window on my 2010 Ford Fusion is not working but the other three windows role up just fine. What could be causing this?
turn key on put window switch in down position and hit door panel hard enough to jar any stuck brush in window motor !ps donot hit hard enough to damage door panel capish!
Dec 19, 2013 | 2010 Ford Fusion 2.5
May go for 6 months ok then does random reboots
I would suggest shutting down at least once a month for general maintenance such as dusting the fans off and cleaning the computer case.
If you are running for 6 months straight with out a single shut down that is negligence on your behalf to your computer & to the hardware inside. A lot of dust that accumulates may not seem like much to you but the amount that does accumulate will damage the hardware given enough time.
I hate to think of how much dust is accumulated inside it I like to give my PC a light cleaning each month. Generally a few quick hits with a compressed air canister is enough to keep the PC dust free.
Sep 16, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I **** the marker. screw in hpa. so far so good. no leaks. fire it a few time and there is a leak coming from inside. i can hear air from barrel and the oval cocking handle hole. i have taken apart the...
Replace all of the o-rings within the gun make sure that the striker pin is free to move. The striker pin is the one that the big striker hits, it is on the inside of the pressure tube.
Apr 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Hard to get pilot lit have to hit striker 50 timea
Not enough info! like model # brand name....serial # and type of unit!
Dec 21, 2009 | Heating & Cooling
I have a Bosch 11236vs and the hammer function does not seem to work properly. The tools move in and out but don't have any impact if you hold them. Dissassembled and everything looks fine, but when I...
Most of the time the o-ring on the striker needs changed. Look closely at the hammer piston as well, once in a while (very rare) the piston will develop a crack that allows air to escape by the striker, keeping it from striking the impact bolt. Make sure to add a little extra grease when going back together as well.
Oct 18, 2009 | Bosch Drills
Dropped Notes
After some tinkering, I was able to fix this problem myself. When I detached the neck, I noticed that the spring-loaded pins from the guitar body had pressed hard enough on the thin contact points that they created holes that went through to the circuit board, thus causing the intermittent signal loss problems. A carefully applied drop of solder on each of the contact points in the neck has my controller now working flawlessly once again.
May 20, 2009 | RedOctane Guitar Hero III Wireless Kramer...
Striker Sticking When Erasing. Brother ML100 Typewriter
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Aug 14, 2008 | Brother ML-100 Typewriter
Brother GX-6750 Typewriter Logo
110 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
