Question about Canon MP610 Photo All-In-One Printer
MP610 How do I duplex print. I have had every second page print upside down. o I manually turn the page over/
  • madhaug Aug 11, 2008
    It says it'll do it automatically, but it need me to put the paper back in the input tray... not very automatic... anyone have a suggestion???
  • Rob Aerts Nov 29, 2008
    I have exactly the same problem. I have tried all settings, nothing will resolve this for me.
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Posted on Nov 29, 2008
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
How do I use my printer as a duplex for making copies on both sides? Thanks Roxanne
The printer does not support duplex coping. If you want to do manual duplex copying, you can make a copy of the first page.
Then reinsert the paper upside down in the manual tray or paper tray, fil the page on the document feeder and make the back copy.
Aug 27, 2010 | Samsung CLX-3170FN All-In-One Laser...
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
When printing duplex document 1st page is upside down
make sure the driver is set to book bind duplex, rather than tablet style which is what it is doing now. Good Luck!
Dec 29, 2008 | Lexmark X9350 All-In-One InkJet Printer
Canon MP610 Printer When automatic duplex printing in landscape orientation, the reverse side is printed upside down. Duplex Printing in portrait mode works fine. Can you help?
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Oct 27, 2008 | Canon Office Equipment & Supplies
Double sided printing
In this printer u dont have duplex print mode,u can use only manully.
Oct 10, 2008 | Canon PIXMA iP3500 Printer
Sharp arm355N/fx/srg
If your printer does not have the duplex module installed, then you are manually trying to print duplex, correct? If so, rotate the first printed batch before reinserting into the printer. On the second pass, the printer will print with the proper orientation.
If you are having problems with the duplex module, section 3-4 of the operations manual has some good troubleshooting tips. Section 3-2 describes printing with the duplex module.
You can read the operations manual here:
http://www.google.com/url?sa=t&ct=res&cd=9&url=http%3A%2F%2Fwww.wisconsinimaging.com%2Fdownloads%2Farm355n_arm455nmanualcopier.pdf&ei=I_OZR_PhIY3YpgSezaT_Bw&usg=AFQjCNG-V-wFgvShiy2YTsn-dgEwrZqmag&sig2=Utq7qqf1Pw6MT9P8YOQfmg
Jan 18, 2008 | Office Equipment & Supplies
Duplex printing
I think you given the wrong printing on one side. So Check the page orientation and do the printing
Sep 29, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Aug 18, 2007 | HP Photosmart 3310 Printer
Canon MP610 Photo All-In-One Printer Logo
188 people viewed this question
old marine
old marine
