Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Timer light continues to flash want power up tried system reset and unplug and still no sucess
  • 120693 Aug 01, 2008
    same as you
  • 927 Answers
Good Day, rstoes01;
Most common problem with TV is the following. The underline is the problem 99.9% of the time.
LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, replace them with part # 181P734030 (680 UFD 16 V).
Good luck, big IRISH.
Posted on Jul 17, 2008
Hi friend,
I had the same problem with my TV that wouldn't do anything but the green light would flash. I'm not a electronics tech or anything but reading their info what helped me was to hold the 'memu' but for 20 seconds then press the reset button. This worked for me and I hope it works for you!
Posted on Oct 07, 2008
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Had a power interuption and now the timer light is flasing and the tv won't come on. Tried reset with no result. Now what?
Green timer flashing is CPU board inside booting program. This is normal after it has been unplugged and lasts for 70 seconds, normally. If it continues blinking, then there is a problem with it not being able to boot. There are bad parts inside; whether the power supply or CPU board, and possible others. It can be OK until it is unplugged/loses power, where it has to re-boot now.
May 02, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Lamp light flashing green continually after power outage. have hit reset button, unplugged tv, nothing works
the timer light will continually flash green.on the dm pcb and fmt pcb you have 4 capacitors
that pooch out.replace the 4 capacitors on both boards.will require a tv professional to do
this.
Jul 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Blinking green light, will not power up
DM module repair instructions chrisandnat.com/projects/blinkingtv/blink.htm
Use four 1000mf 25v 105 degree capacitors for repair......T.
Jan 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
