My motherboard is ESC socket 754 K8M800-M2
I clear the cmos by puting the jumper into 2-3 but i forgot to pullout the baterry first and now itz does not turning on... what shall i do??? can u help??
  • Anonymous Oct 25, 2008
    Temperatures:
    Motherboard 48 °C (118 °F)
    CPU 62 °C (144 °F)
    Aux 96 °C (205 °F)
    Seagate ST360014A 49 °C (120 °F)
    WDC WD1600BB-00GUA0 45 °C (113 °F)
    Voltage Values:
    CPU Core 1.41 V
    +2.5 V 2.58 V
    +3.3 V 3.36 V
    +5 V 5.08 V
    +12 V 5.25 V
    +5 V Standby 5.11 V
    Debug Info F FF FF 00
    Debug Info T 96 41 19
    Debug Info V 58 A1 D2 BD 52 63 65 (77)
  • 8 Answers
If your motherboard does not turning on try to check your memory module sockets cleaned and the video card and test your memory module if its okay to other motherboard. If not there is a problem with your bios program it might corrupt or the motherboard itself has a hardware problem.
Posted on Jul 23, 2008
  • joer ads Jul 23, 2008
    By the way check the cmos reset jumper and should be set to 1-2.
  • 84 Answers
Does it give any type of beep code ? do you see any L.E.D light on motherboard light up ?
If no beep code the mobo might have met it's maker
Posted on Jul 19, 2008
My ecs k8m800 m2 rev 2.0 is no power. just stndby,
check all leads from motherboard to hard drive including electrical extensions and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
hope it helps
Apr 21, 2012 | EliteGroup ECS K8M800-M2(2.0)...
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    I dont have mother cd with me and i need to install the mother board cd in my computer becoz display are not working properly
    Your board has Socket 754, VIA K8m800 and KIA VT8237 chipsets With Realtek sound. S3 Graphics Unichrome. This is Gigabytes link to downloads. I ahve entered your info but will outline for you.;
    http://www.gigabyte.us/support-downloads/download-center.aspx
    Option 1
    1 Select Product catagory Motherboard
    2 By socket- socket 754
    3 By chipset-VIA K8M800
    4 Model Name- GA K8VM800M
    Click search
    New screen, scroll down and enter o/s
    Drivers will show up Scroll down to VGA Driver and pick
    "VIA K8M800 Driver. scroll to right and click on "America"
    This will give you your most recent driver.
    Mar 26, 2011 | Gigabyte GA-K8VM800M Motherboard
    Can biostar k8m800 m7a 754 run windows 7
    The processor will run windows 7 but may not be very fast.
    Look for the correct driver for the m/b at BIOSTAR.com
    Dec 27, 2009 | Biostar K8M800-M7A Motherboard
    Motherboard ESC k8m800-m2 (v1.0A) 2x1Gb RAM
    You have to verify the in the motherboard book if the brand name or vendor of your merory stick is compatible with your computer's motherboard, there all written : Kingston, Samsung, micron etc... Check all details if meets your motherboard's model requirements and make the change if necessary.
    If all details are correct, check in your motherboard's manual if there is a special configuration to respect (in withc bank you should place your memory stick and witch order etc)
    Sep 02, 2009 | Computers & Internet
    Intel r awrdacpi vga driver
    1. Go to: http://www.ecs.com.tw/ECSWebSite/index.aspx?MenuID=44&LanID=0
    2. Under "Products", click "Motherboards"
    3. In the left margin, under "Products Search", select "Motherboards" & "Socket 754" from the 2 drop-down menus under the "Product Category" section.
    4. Under the "Model" section, select "K8M800-M2"
    5. Check your motherboard's version & select it from the drop-down menu under the "Version" section, then click "Submit". You can find your motherboard's version printed on the motherboard itself where the model is also printed. You will need to open your computer case & check.
    6. After clicking "Submit", a page will be displayed with all details about your motherboard. You will find a small section to the right labeled "Downloads" with a floppy disk icon. Under that section, click on "Driver". This will open the page where you can download all drivers for your motherboard.
    Jul 07, 2009 | EliteGroup K8M800-M2 Motherboard
    I cannot reads the pinouts on the mb albatron k8m800-754 ineed to plug in power sw, reset sw,hdd led etc
    ftp://ftp.albatron.com.tw/product/it/mb/PDFzip/Manual/VIA/K8M800-754/K8M800-754_EG102.pdf
    Download the manual, on page 15 you will see how ro connect the front panel cables
    And here is the supportsite for that mobe incase you need any drivers
    http://www.albatron.com.tw/English/product/mb/pro_detail.asp?rlink=Specification&no=196
    If you need more help just let me know
    Good luck
    Dont forget to RATE me
    Nic
    Mar 12, 2009 | Abit KV85 Socket 754 K8M800 Athlon 64 ,...
    Computers & Internet Logo
    830 people viewed this question
    David Payne
    David Payne
