Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
Trying to install ATI Diamond Viper x1600 AGP Pro graphics card
I tried to install my video card, which is 8x agp. When I boot it, I get smoke on the screen and then the screen goes black. The cables are fine and clean and connected properly. The card was working fine on my old mother board. I tried to power it again, and it worked...until I powered it off and booted it up again. same thing, smoke. What should I do?
  • 67 Answers
Reseat the videocard. Could just be loose or rusty.
Posted on Sep 17, 2008
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
Motherboard doesn't recognize new video card.
do you have an nvidia motherboard? this may be the cause of it.
Dec 09, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
Can I upgrade the graphics card on this board installed in my SA85??and if so what slot format - PGI or ....??
u probably hv Integrated SiS Real256E Graphicson ur board..if u r using so, u can upgrade using any 'dedicated' 1 x AGP 8X/4X Card..like:
Diamond Viper ATI X1950PRO AGP 512MB
Radeon 9200 128MB AGP8X
eVGA GeForce FX5200 128MB so on....
..contact ur system admin/vendor for details n preference....
Oct 27, 2009 | AcerPower Sn PC Desktop
ATI Radeon x1600 Pro unstable in Dell XPS desktop
If you have the latest drivers installed, try uninstalling them, and going back to the 2nd most recent driver released. Sometimes the latest drivers have issues. Work your way back trying multiple drivers if possible until you find the sweet spot. You might try this website, it has a driver cleaner that removes old drivers. Then try reinstalling the driver of your choice.
http://www.afterdawn.com/software/desktop_software/other_tools/driver_cleaner_pro.cfm
Sep 02, 2009 | ATI RADEON X1600 Pro 512MB AGP Graphic...
VGA problem
plz dont use vista !
use xp for game performance ...ur vga driver may not have the ability to install
so use xp
thank u.....
Aug 06, 2009 | Viper Diamond ATI X1600 PRO AGP 512MB...
Old Geforce 7300 works fine on Windows XP, when I insert Ati x1600, the motherboard fan turns for two seconds, then stops, the system will not boot. I have a 400W power supply, even though the ATI X1600...
1-go into safe mood and verify that the card is recognized
2-if you cant enter safe mood for some reason use ati flash just type atiflash -i
3-if you cant boot at all then try using a pci card and check for the cards status
either your power supply is faulty or something in the bios maybe wrong......you should give more info
Apr 01, 2009 | ATI RADEON X1600 Pro 512MB AGP Graphic...
ATI Radeon HD 2400 Pro install - computer won't boot when added
Click here to for your computer product specification.
ATI Radeon HD 2400 Pro is a PCIe and your computer is compatable only for PCI
hope this helps,
Thanks, Prem
Feb 18, 2009 | ATI Diamond Multimedia Stealth RADEON HD...
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
100 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
