Question about Car Audio & Video
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
  • 373 Answers
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Posted on Jul 17, 2008
What would cause my alternator and battery to keep dying in my 1991 dodge caravan
Disconnect the negative of the battery. is there a amp installed or just a radio After market or updated factory. How old the battery remote start or no remote start after market remote start cause this problems
Jun 20, 2014 | 1991 Dodge Caravan
I am doing a stero in a 2001 silverado with a 6.6l disel and there are 3 wires on the back of the factory stero the after market stero only have one will i need to wire the other 2 in
The best thing to do is use a factory wire adapter. The main wires you need to worry about are power, battery memory, ground and speaker wires. If you have a power antenna you will need to wire in the remote (normally blue or light blue). The only other wire should be an orange wire for the dimmer on the radio face. This one is not necessary for normal operation. Make sure you have the main 11 wires wired in. Ignition, battery, ground and the 8 speaker wires.
Apr 27, 2010 | 2001 Chevrolet Silverado
2008 Dodge 3500 Quad cab need the colour for a switched power wire on the steering column to turn on an after market stereo
if you take factory radio you need a steering volume control module to work with it have to get one install by a qualifier stero technician
Oct 13, 2009 | 2008 Dodge Ram Pickup 3500
96 dodge caravan radio wires
see an auto sparks ,or take to a local radio fitting shop ,no good telling me here because colours of wires can vary between manufacturers of both the radios and the vehicles
Aug 07, 2009 | 1996 Dodge Caravan
I need to know how to install a pionear sterio into a 99 ford focas i have the wire harness and kit i just need to know how to dismount the factory sterio and what wires go where
You need the factory car stero keys, its like a u bracket one slides in either side then you just pull it out with them.
as your wires there colour coded :)
Feb 21, 2009 | Pioneer DEH-P6800MP CD Player
I need a stereo wire diagram colorcode for 1996 dodge caravan
wal mart sells after market plags for this car
and they are around 6 to 12 dollars and include the diagram to wire it in (if the factory harness no longer exists)
Jan 02, 2009 | 1996 Dodge Caravan
Trying to find the location of the starter
Try looking on the front side of the engine between the oil filter and transmission.
Removal & Installation
  1. Remove or disconnect the following:
    • Negative battery cable
    • Starter harness connectors
    • Starter motor
To install:
  1. Install or connect the following:
    • Starter motor. Torque the bolts to 35 ft. lbs. (47 Nm).
    • Starter harness connectors. Torque the battery cable nut to 100 inch lbs. (11 Nm).
Jul 25, 2008 | 2000 Dodge Grand Caravan
Radio Wire Colour help
One easy way to know which ones are the speaker wires is by using a double AA battery and connec one wire on any side of the battery and just tap the other side of the battery with a nother wire and when you find the right one you will hear the speaker make a sond keep doing this until you find all the speakers well I hop this helps.
Jul 02, 2008 | 2005 Dodge Caravan
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
Car Audio & Video Logo
228 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
