Question about GE Microwave Ovens
I would like to know how to clean the inside of my microwave,the wrong cup was put in,and it caught on fire ,and I can't get smoke stain out. Thank you,Molly Dickerson
  • 100 Answers
The smoke stain is almost impossible to remove as smoke tends to get in the pigment of the paint.
If there's a burn smell, you can try simmering a lemon juice and water mixture for several minutes in the microwave. You can also set a plate of charcoal briquettes inside and leave the door closed overnight (DON'T turn the microwave on - just let it sit). Keep the charcoal inside when not using the microwave and it will absorb a lot of the odor.
Posted on Jul 17, 2008
Over cooked noodles ,food caught fire, no visible external damage,some smoke black, but control panel dead completely.What can i do ?
Probably the main fuse has blown. If there is damage to the inside of the microwave I would seek professional service to ensure that seals are still working.
May 08, 2015 | Goldstar Microwave Ovens
Sharp Carousel microwave - 1200 watts - Model R530EKT - caught on fire while using
you must carefully and read your instr. manual if some material inside the microwave can be produce fire. Otherwise the microwave can be old and the electronic component deterioring and cause exploding.Some time the material inside from the microwaves, is corroded, and the irradiation can be produce Fire. Tes the indication given.
God bless you
Oct 01, 2012 | Sharp R-510HW Microwave Oven
Sweet potatoe caught fire in my microwve
the magnatron super heated the paper combined with what we in the industry call super combust your micro should be ok to use just keep it clean and if you use toweling wraP it around rather than cover
Apr 21, 2010 | Amana ACO1860 Microwave Oven
How do I clean the inside of the microwave? It is
DO NOT use SOS pads! They are made of STEEL WOOL and will remove the protective finish inside the oven cavity. Without the protective coating, the microwave can arc internally and ruin the magnetron. Use the green scrub pads you find in the dish detergent section of your local grocery store. They are considered non-abrasive. Use the green scrub pads along with a non-abrasive cleaner such as Soft-Scrub or 409. Wipe clean with a fresh water and dry with a clean cloth.
Jan 30, 2010 | Sharp R-1505 Microwave Oven
After cleaning, the microwave worked but
I am still working on the problem. So far the exhaust fan, the light , the clock and light inside the heating chamber has started working. I am going to sit back and think and look for the part that shorted out. Since the unit is 29 years old the bad part may not even be available. I will keep you advised after I find the culprit part. The information may be beneficial to others. Thanks
Dec 02, 2009 | GE Microwave Ovens
Is it safe to use a microwave if some thing inside of it caught on fire?
Its no problem at all so long as it still runs normally. Only problem, is the smell will annoy you for a while. Give oven a good wipe down with a good cleaning agent.(I'm assuming the fire didn't get out of control).
Sep 27, 2009 | Microwave Ovens
Decor DMO2420 Microwave caught on fire
Please write back with more details if this reply doesn't solve it.
(Such as, Was the fire inside the cooking cavity? Has the inside been cleaned since?)
There is a cavity temperature fuse located under the outer cover, on the top left side of the cooking cavity. It is rated at 150 degrees centigrade.
If there is a fire, that will open, killing all power to the unit.
A replacement can be found at a local appliance parts company.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 29, 2008 | Microwave Ovens
Popcorn stain in Microwave
Uhhhmmm, paint? Inside a microwave? YUCK.... that would make food taste like paint.
The yellow stain from microwave able popcorn is most likely a permanant issue. I have heard of the vinegar water, bleach etc working, but never had it work for me.
I don't recommend you painting the inside of a microwave. Some paint is flammable. Almost all paints are toxic.
May 14, 2008 | GE JVM1650 1000 Watts Microwave Oven
I've had a fire
best way to remove the smell is to get an activated charcoal cooker hood filter (cheap and available at any hardware store) and leave it scrunched up in the microwave for a couple of days with the door shut.(also a bowl of fresh cat litter works if it is the "fuller's earth" type without extra super-scented-power-globules etc..) If you are competent enough to take the cover off (make sure you know what you are doing or get a repair man to do it) then clean all round the extractor fan blades and where the air is ducted - there may be some soot that smells in this area. If there are no obvious holes in the interior as a result of the fire then if the machine seems to work normally there is probably no problem. the only way i know to remove this type of stain is with a (plastic scotchbrite type) scourer with some neat bleach (wear gloves) or some "cif/jif" type scouring cream. if a bit of effort with one of these doesn't do the job then you are probably best to live with the stains - make sure you clean all the cleaning products off properly before cooking in the machine again. If none of this works then try microwaving some sugar until it burns (watch it and stop it the moment it catches fire if it does). Sometimes this can remove burning smells even if this sounds very stupid it can work. last resort anyway. Hope this helps :)
Mar 08, 2007 | Samsung MW5350W Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
193 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
