When I try to run the installation disk I get the following error: The Directory name is invalid.
  • 781 Answers
What installation disk
Posted on Jul 17, 2008
Hi i install Exceed got error message :"error 1317 :an error occured while attempting to create the directory c:/programdata/hummingbird/ connectivity/12.00/global/exceed". Suggest me how to solve this...
To resolve this problem ensure that you have the necessary permissions on your hard disk or disks. To do this, follow these steps.
Note: because there are several versions of microsoft windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
1. In windows nt explorer, select the folder.
2. Right click the folder, then click Properties on the shortcut menu.
3. On the security tab, click permissions.
4. Select the "Everyone" group, then click "Full Control" in the Type of Access List.
5. Select the Replace Permissions on Subdirectories check box.
6. Click ok.
7. Click yes to the prompt confirming whehter you want to replace permissions on all subdirectories.
8. Click okay in the folder name properties dialog box (where folder name is the name of the folder that you selected in step 1).
9. Run Office set up.
Sep 05, 2013 | Hummingbird Computers & Internet
My harddisk says invalid disk data no data files found
Sorry to hear of your difficulty. Usually in your kind of situation data can easily be recovered using any data recovery software.But my personal suggestion to you is to first try to run a demo version first and if you see directory list of your lost data then only proceed with the purchase.
Sometimes when OS fail to install then file System of your hard drive can go corrupt which can result to invalid disk error.
Regards,
Stellar Phoenix Solutions
http://www.stellarphoenixsol.com
"trusted data recovery solutions"
Feb 13, 2012 | Verbatim SmartDisk Firelite Portable USB...
ON INSTALLATION OF TRIAL VERSION OF PAGEMAKER 7 ERROR MESSAGECOMES SAYING ERROR 115 PLEASE ADVISE
Issue
Error 115 when installing Adobe FrameMaker 7.0 or 7.1 on Windows
Solutions
Do one of the following solutions:
Solution 1:Disable anti-virus applications, and make sure all 3rd party applications are closed before installing.
Solution 2:Copy install files to HDD are run setup from that location (Frame installer lives in FM directory)
Solution 3: Remove all files from %temp% and %windir%\temp and reinstall
Background information
Error 115 from the InstallShield help reads as follows: "Specified file cannot be opened as write. An attempt was made to overwrite a locked file belonging to a file group that does not have the Potentially Locked or Shared property set to Yes; an attempt was made to install a file with a long file name (or to a folder with a long path name) in a 16-bit setup; or the path to the target folder is invalid."
Apr 10, 2011 | Adobe PageMaker V7.0.2 for PC
Invalid form for short nick name
I assume you are running snow leopard on a MAC.
Please click on the link below and download and install file, this should resolve the issue.
Mac printer drivers.Brother printer drivers for Mac 10.6:
http://www.apple.com/downloads/macosx/apple/firmware_hardware/brotherprinterdriversformacosxv106.html
Apr 18, 2010 | Brother MFC-685cw InkJet Printer
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Power MAC G4 "Invalid directory record length"
Use Tech Tool or Disk Warrior to try and repair the file, failing that use Install disk (OS x) and go to install, select options, select install and archive and that will give you a new system without losing any data or apps. You may have to re-install some 3rd party apps/ passwords, but all in all an easier fix than erase and install. It may be worthwhile if you do get it up and running to back up all your data, as the HD may be on it's way out.
Aug 19, 2009 | Apple Mac OS X 10.4
Trying to load QB on my computer
Are you sure that's the correct startup file? Look for setup.exe or right click on Autorun and select run. You should be able to select the install directory if you want.
Mar 27, 2009 | Intuit QuickBooks Pro 2008: Windows
AGV 8 (build 233) Installation
Make sure all other antivirus software is removed before you try to install it.
Also, run a scan for existing infections with an online scan like TrendMicro = http://housecall.trendmicro.com or
Panda http://www.pandasecurity.com/activescan/index/?track=1&Lang=en-US&IdPais=63
Feb 03, 2009 | Microsoft Windows XP Home Edition
D:\ directory name invalid message
that error message is for the DATA BUS CABLE, you need to buy another DATA BUS CABLE, and verify the right connection contact in the Back of CD and the Main Board for this DATA BUS CABLE
Nov 26, 2008 | Compaq Presario 5000 PC Desktop
MS Office 2007
First uninstall the MS Office 2007 on your system, then go to the target folder directory where you just installed the Office2007, its usually under PROGRAM FILES folder, and locate the right folder (usually named as "Microsoft Office") and DELETE manually this folder.
Second, restart your computer, then try to re-install the Office 2007 again.
I hope this procedure works.
-mrsolution
Jun 11, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
