Question about Radio Shack TRC-503 CB Radio
Radio shack cb radio 21-1703
Stupidly I plugged it into a wall outlet and, of course the fuse blew. I can't find a 2A 125V fuse. Only a 2A 250V. No power. I connected the wires to a cigarette lighter plug. No power. I tried it touching the two ends without a fuse. Still no power. If the fuse blew, isn't the unit still protected? Suggestion?
  • SBarnes Jul 17, 2008
    Thank you for the response. I only plugged it into the wall once (first). No other fuses have blown but maybe the wall power blew the diode you mentioned? If so, if I can see which item is the particular diode, I'd like to try to solder in a replacement myself (more satisfying).
    SBarnes
  • Dean Pitts
    Dean Pitts May 11, 2010
    There is a protection diode, which probably blew. This usually happens when the power and ground wires are connected in reverse. I assume this is probably what happened, though I am not positive since you connected to ac instead of dc power. The reason the fuse keeps blowing is that with the diode blown, there is now a short between ground and power, which is to prevent further damage to the radio. You should be able to take it to a cb repair shop and have them solder a new protection diode in place for either $10 or $15, as long as that is all that was damaged.
    As for the fuse, a 2a or 3a 250v will be fine. Typical tube fuses you find in parts stores or electronic stores will be rated at 250V. You need to be more concerned about the amps not the voltage. The higher the amp rating, the more amperage is allowed through, which can damage parts during a power surge.
    Dean
  • 126 Answers
OK. I do not know the exact number for the diode off hand, because I don't have the same radio in front of me. On most cb radios, this diode is usually located on the component side of the pc board, close to where the positive lead solders to the board. Most of the time when it burns, it just becomes brittle.
If you do replace it on your own. The diode is called a rectifier diode, which you can pick up at radio shack or at partsexpress.com. The part number is between 1N4001 to 1N4008. When installing be sure to observe polarity, making sure that the side with the silver band is facing the direction of the arrow.
If I can help anymore, please don't hesitate to ask.
Dean Pitts
Rollin CBs
rollincbmods@yahoo.com
Posted on Jul 19, 2008
Is there a fuse inside the grinder to protect it from an electrical surge. I accidentally plugged it into a 220 volt outlet.
My MDF was built in September 1993. It has a fuse inside a black cylindrical fuse holder on the electronics board that sits aside the motor. If you have a right-angle flat blade screwdriver, you can get the fuse out without removing the motor unit from the case. I didn't have the right tool, so I ended up removing the motor/grinder unit from the case to replace the fuse. The fuse is a 2A/250V Slow Blow. I used a Buss CDC-2A to replace the factory "5TT 2A/250V" fuse.
May 09, 2011 | Gaggia MDF Electric Burr Grinder
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Radio Shack TRC-503 CB Radio Logo
316 people viewed this question
Top Radio Shack Radio Communications Experts
Iron
Iron
Robert McClure
John
John
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
