posted by spawn6177 on Jul 17, 2008
Hey experts, I was setting up a private server for a game, I know I have all of the settings I need to be right, however no one could connect to my server except for myself, no firewalls no antivirus, nothing to stop someone from getting in. I started to fool around with the settings in the modem to see if I could get it to work, now my internet light is out my internal and external ip's have changed. I had to go through the connection wizard to set up a new way to connect, it works but it is a real pain because now I have to manually start it up where it was always connected before. Hope I gave enough detail, thanks!
Best Solution
posted on Jul 17, 2008
try going to START>> control panel>> network connections>> right click on Local Area Connection>> properties>> highlight internet prtocol TCP/IP>> click on properties>> choose use the following DNS server addresses.. it will ask for a preferred and alternate dns server address that shud be given by your Internet service provider..
this solution can help you not to manually configure your connection everytime
Rating Locked! (?) spawn6177 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Westell Wirespeed LiteLine 6100
Email this problem
Email this problem
Can you Help with these Modems problems?
Westell Wirespeed LiteLine 6100 (B9961001002)...
I can't get DMZ on Westell...
Hi I have the revision... Answer This...
westell 6100 ethernet
I can connect to the internet... Answer This...
Repair Service
Find Modem Repairman Near You:
