I recently (accidentaly) bent the usb plug thing, the silver bit while it was in the computer. I'v opened it an can see small amounts of damage but dont now whats stopping it from working
  • filbjakeo6 Jul 17, 2008
    Aditional infomation
    I realised i failed to mention that its a flash drive
  • 4 Answers
If wires are busted, you're out of luck. Could try taking it to a tech type to see if they can pull the information off of it, but odds are you're looking at buying a new flash drive.
Posted on Jul 17, 2008
I dropped my phone and the screen cracked a tiny bit underneath the silver part at the top of the phone the phone now has a black screen
Alcatel One Touch Fierce Teardown - iFixit
https://www.ifixit.com/Teardown/Alcatel+One+Touch.../23019
iFixitiFixit - Alcatel One Touch Fierce Teardown: Tearing down a water damaged Alcatel One Touch Fierce from Metro PCS. ... It seemed to have quite a bit of adhesive. ... I have NO experience replacing a cell phone screen and this teardown ... I opened thephone and the little silver piece on the power button cable fell off.
What is covered by mobile phone warranty? ' Geek Squadwww.geeksquad.co.uk/.../What_is_covered_by_mobile_pho...Geek SquadOct 22, 2014 - A warranty is a manufacturer's guarantee to repair your phone or ...Alcatel, 12 Months, 6 Months .... "Does rooting my Android phone void the warranty?".... been dropped with enough force to break the small piece of glass!7 Practical Things You Should Do After Cracking Your ...www.makeuseof.com/.../7-practical-things-you-should-do-after-cracking...Jul 30, 2014 - Or, well, maybe you just accidentally cracked your phone's screen in a normal .... Id like to think that it protects my phone that little bit more.
Dec 16, 2015 | Alcatel One Touch Idol 2 Mini
I accidentaly broke the input on my toshiba canvio 3.0 portable hard drive
my personal solution to this isnt somthing most people would try ever but i do it all the time for people with broken flashdrives. if its anything like what ive dealt with. just find the seam or skrews keeping it together and take the whole thing apart, if its a normaly a small laptop like hard drive it will most likely have a sata connection and will be easy enough to connect directly as a slave to your computer and you can pull all the information off if it. if it isnt like most other hard drives then you may need to find a connector like it off of ebay. if you dont feel comforable doing this. find someone who is
Sep 20, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
Whenever I plugged my webcam in, I have to wiggle the wire around a lot and if I touch it when its working, it stops. Now though, It won't work at all. Can I fix this?
It sounds like your USB terminal on your computer is bent or damaged.
This often happens.
Try using another USB port as there are usually multiple ports on the computer.
If this still doesn't work, the camera's cord may be what's having the issues as the terminals and contact points inside are bent.
I would consider getting a new webcam or replacing it if you have recently purchased it.
Hope this helped!
Thanks!
Jun 13, 2011 | Cameras
My computer problem is no power, no nothing. I have 2 usb slots, one on top of the other on the front of my computer, and recently the bit of metal seperating them has been bent out of position. Although i...
there is no problem on your usb and a mental that separated them.. and also the cable it seems to be in good condition try to replace the power supply of your computer.
Apr 19, 2011 | Computers & Internet
My drive is almost fill a 4g now when i plug it in it is not reading any of the stored files.
Hello there!
USB flash drives in general, are wonderful little tools that allow people to store a relatively a large amount of data in a compact and portable interface that is extremely easy to use at all. The downside of storing lots of critical data on a USB flash drive, however, is that they're fairly susceptible to damage and that you can lose all of your information immediately if something goes wrong. When troubleshooting a USB flash drive, there are several key things to check and to remember that will help you to determine whether your flash drive is destroyed or not.
1. Look and see whether or not your USB flash drive's indicator lights are activated when it is plugged in to your computer's USB port. The vast majority of USB flash drives have small LED lights located somewhere on them that flash intermittently when they're hooked up to a computer. If your light does not turn on, then it's either not plugged in properly or is damaged and likely not repairable.
2. Make sure to download and install the right driver software for your USB flash drive.
3. Try your USB flash drive on more than one computer before giving up on it altogether. If it works on another computer, then the problem is likely with your computer hardware or software, not with the USB flash drive.
4. If you cannot restore your files, you may use a third party software to recover them.
Regards,
fossildude
Mar 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Want to install the software for the Flip Ultra Hd for Windows 7 64 bit. How do I do it? Where do I get the software?
Actually I recently spoke to Flip Video about the same thing since I need to get a new computer which will be Windows 7 64 bit.
They said to just plug the camcorder into the computer USB 2 port and the camcorder will open FLIPSHARE on your computer screen and will download the updates itself unless you stop it from doing so.
Feb 15, 2011 | Pure Digital Flip Video Ultra Camcorder
I read the post about the Silver Moon continualy shutting off and requiring the new hose part SES 125. However, what i have noticed with my Silver Moon is that it only shuts off when using the floor brush....
Hi.
My wife has the same vacumn, and has already replaced the hose, and again it was shutting off continously with the power head.
Rather then spring another $150.00 plus for a new hose, I decided to take it apart to see if it had a shorted wire..
There are several small screws along the length of the control portion, as well as two small screws that hold the end cap (where the hose goes into the heavy plastic control part),
When I got it apart I did not see any shorted wires...however what I discvovered was where the hose "swivels" are 3 metal contact bands, and some electrical lubricant.
On the other side was a small circuit board with three paper thin copper contacts which lined up with the metal bands.
The bands looked a bit worn.
So I ever so gently bent the copper contacts out just a tiny amount further, and gently cleaned (with a bit of alcohol) the metal bands to take justy a tiny bit of what looked like an excessive amount of electrical grease.
I reassembled the unit...and so far so good.
Jan 15, 2011 | Miele s558 Silver Moon Vacuum
My monitor gets no input signal, computer does
Try the montor on the external vga connection of the laptop. You can swap the signal from the laptop screen to the external monitor using the swap key (usually a FN key). You can do this whilst the laptop is up and running. If you see the display there, then you know the monitor is o.k. Then check the connection to the PC. If it is a card (PCI/AGP) make sure the card is properly seated. If you don't see display on either check the pins on the monitor plug if any are bent or missing. Sometimes these pins can be accidentaly pushed back into the plug housing. You can retrieve them with small long-nosed pliers.
Sep 16, 2009 | Xerox XA7-17i 17" LCD Monitor
I/o Magic 320gb external hard drive--how do i open it?
on the back where you plug things in, there is a silver piece of metal. you need to pry that open with something. i used a tweezer and put it into the edge of the usb port to pry open the silver metal. the silver metal is just stuck onto the black plastic. once you get that metal off, there are two screws. unscrew those and you should be able to get in!
Jan 10, 2009 | Electronics - Others
Computer wont turn on
"Then I came across the recommendation to check the USB ports for damage. Saw some of the pins bent inside the port. Once I fixed them, the computer powered back on as normal! Small fix for big problem. Cheers - Parveen"
My wife's Dell E510 also suffered from the orange blinking light on front, and would not power up this morning. I had just purchased a new power supply for another computer and swapped it with the Dell's. To no avail... Put the Dell back together and still no luck with a start. So I came across your site and remembered that recently the 6y'o had jammed a USB port in the front of the Dell and after bending that USB port back into shape every thing works again!
Who would have thought that a free fix would be so easy!
Thanks!!!
Feb 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
57 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
