Question about InFocus IN72 Multimedia Projector
Vertical lines i don't seem to have the cable to do the upgrade, but i have the previous upgrade to the system. what else could be causing it. tried the reajusting but now i have more lines
    Problem Solver:
  • 11 Answers
Mainboard is fried. shawn at avalontc.com
Posted on Aug 06, 2008
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Hi I have a samsung plasma PN50C550G1F I havve right now 2 vertical lines that seem to change color with the background picture. Tv powers up fine sound work perfect.
Vertical lines on a plasma TV are caused by either a failing x-buffer board or a loose connection at the flex cable between the panel and the buffer board. Sometimes just removing the flex cable, cleaning it, snd reinstalling it will fix it.
Mar 17, 2015 | Samsung Televison & Video
Vertical line
Run diagnostics on the system, will determine if that is a hardware issue or something related to drivers.
For drivers - obvious first choice is to download the latest drivers from support.dell.com and upgrade
For hardware - you will need the LCD to be replaced, for the lack of other smaller parts you can't order from Dell.
Before you determine hardware, go thru the system teardown documentation and reseat all the LCD parts / cables (usually fixes the line issue, without replacement)
Sep 13, 2013 | Dell Vostro 1510 Laptop
Vertical lines when turn on
In most cases, loose connection to LVDS cable [the flat cable that connects the LCD panel to T'Con board] can cause this fault. If you are something familier with LCD TV repair, just re-seat this cable once and check. If you wish to get more assistance, try this site. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by entering the brand name to your device in the search box of the display window, or view it in Mosaic / Flipcard / Timeslide option.
Aug 22, 2013 | Televison & Video
Green Lines from cable, DVD works fine
It seems to be a strange fault indeed. Anyway, check this link. It has details and troubleshooting chart to Panasonic TVs. Check it and take all measures according to the troubleshooting chart. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 02, 2013 | Televison & Video
I need to reset my tv and don't know how
if their is a vertical lines the cause it could be loose connection in the cable going to t-con board which drive signal at the screen panel display. tried to re seat the LVDS cable.
Sep 01, 2012 | Proscan 26LA30Q 26 in. LCD Television
I have vertical lines my 26TA1600 LCD TV. The lines seems to be permanent. What is the cause and how can I resolve it?
These vertical line are possible causes of LCD cables from the graphics card. There is no easy fix for this issue and normally requires servicing or part replacement. Try to contact your TV support people or consult you local technicians to diagnose it properly as it might be also the panel itself failing.
Apr 07, 2011 | Philips 26PF9966 26 in. LCD Television
Vertical line on new TV, for some channel
It seemed an antena problem. Previously I did not connect with antena with a proper cable. Now
with a new cable, the problem has been sorted out. Thank you.
Jun 11, 2009 | LG 42PC1DA 42 in. Plasma HDTV
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
InFocus IN72 Multimedia Projector Logo
60 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
