Question about Intel Motherboard
Wont power up ecs motherboard
I have a ecs 945p-a ver 1.1 motherboard. With the 4 pin aux plug installed motherboard will not turn on with it unplged it turns on but than i have no video
  • 55 Answers
Your 4-pin power connector supplies voltage to your CPU through some series of MOSFET transistors. First try to disconnect your CPU from the socket and power up your motherboard. Your CPU might be toasted. MOSFET transistors might be bad. Also look at your big caps around the CPU. If they have bubbled tops, you need to replace them.
Good luck
Posted on Jul 17, 2008
My graphics card is not being recognized. Im using a ECS 945P-A Ver: 3.0 motherboard which has no on board video output. im using a Zotac Technology GEforce 7300 GT graphics card too. Do I need a powe
I don't believe that graphic cards of that level need PCI-EX power directly from the power supply (using a power supply cable with a PCI-EX connector). This is a good thing, but that's because this is a low-level card--one that likely needs nVidia legacy drivers: It's likely that active driver support has ended. (The same is true for legacy AMD/ATi cards--and other more ancient cards, as well. ((PCI or AGP) Sabre, 3DFX, etc.)
If you're using the VGA port--perhaps the card's DVI port is needed for initial install, instead--or vice-versa. (You'd need an adapter or different cord to run to a VGA monitor or TV's VGA port .)
Rarely, two VGA ports might exist on a card, instead. In any case, the port needed likely isn't the one connected (with a ribbon cable) to the PCB on the video card. (Once you get a workable video card driver installed, then you should be able to use either port.) Try all usable ports before finding another possible solution....
Apr 05, 2014 | ECS 945p-a Intel 945p Socket 775 Atx Mb...
Video card for 945p-a v3.0
Hello you can read all about the mainboard here:
It should be compatibel with PCI-E
Good luck
Apr 26, 2012 | ECS 945P-A (V3.0) Motherboard
I need a wiring diagram so i can wire my board correctly
There are 2 versions for your motherboard, refer to the one you have:
Ver. 3.0 - here
Ver. 1.1 - here
The manual contains all the info you need for your motherboard!
Best regards,
Jan 14, 2011 | ECS 945P-A (V3.0) Motherboard
Unable to get the computer to boot up completely.
1. Check the floppy cable; you may have disturbed it when you swapped HDD.
2. and the power connector to the floppy...
3. You could always reset the BIOS....
3A. short-out the two "reset" pins next to the BIOS chip or near the mobo battery.
Sep 22, 2009 | ECS 945P-A (V3.0) Motherboard
Sound driver for 945p-a ver 1.1.can u help me
Dear user,
All the drivers can be found here:
If you can't find it here look here for second chance:
Nov 15, 2008 | ECS 945P-A (V3.0) Motherboard
Ecs 945p-a install hdd sata
Choose in bios the setting about HDD. Choose Enhanced Sata compatibility. Now you can plug4 satas
Sep 23, 2008 | ECS 945P-A (V3.0) Motherboard
Everything works, but no display
Try a different stick of RAM. Like a smaller amount. try 512MB and see what happens. if 512 works, try the 1 of the 1GB sticks so you can still have atleast have 1GB.
Jun 11, 2008 | ECS 945P-A (V3.0) Motherboard
Intel Motherboard Logo
81 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
