Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Convergence-red the red seems to be way off the chart, menu setup dont seem to correct it. what should be done. done minor repairs to TVs. GOLDEE.
  • 1 more comment
  • compton_77 Aug 10, 2008
    red is not off by that much, off by 1" or so? is there a way to adjust it in the menu?
  • ANDERJAM4 Aug 24, 2008
    Have the same problem. Had the repairman here and was quoted $420.00 to repair, new convergence power board and asst resistors. Does anyone know if this is a fair price ?
  • Jan Glas Aug 27, 2008
    replaced stk 392-110 plus 3,9ohm resistors red out,need service mode code for sp43t8 please
  • Samsung Master
  • 8,617 Answers
Replace both convergence ICs you can get replacement ICs at the following link with instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Jul 17, 2008
Is there a way to manually adjust the convergence on a Hitachi HDTV modol #43FDX15B?
Hi James,
If Auto Focus (Auto Convergence) won't complete the set-up stop trying to adjust it. There is a fault in the convergence circuit!! ICs have to be replaced and maybe some burnt resistors.
If you access the service set-up menu and try to adjust the "defective" circuit the Auto-focus may not work correctly after the IC's, etc are replaced. Experienced technicians know that the service menu allow easy resetting to correct the misalignment, etc. "First Time" technician can be easily misled, waste a lot of effort and never get a correct picture.
If you want to attempt the repair, buy the correct parts from a service guy that does this type of work. I suggest having the repair done by a local competent technician that is experienced with Hitachi Convergence Problems. It is considerably more challenging than changing a fuse.
Our Convergence Gallery shows a variety of Convergence Faults. If you live in Toronto, ON., Calgary, AB., or Vancouver BC. it costs $257 for Hitachi in home convergence repair.
Good luck.
Robert
Nov 17, 2015 | Hitachi Televison & Video
Red & green shadowing on the right side of picture
First thing to try is a convergence but with the red shadowing seems to me that you may have your color gun going. Convergence can be found in your video menu on your setup screen. Once in the menu you can adjust the colors to line up. This usually has to be done on a tv that has been moved.
Nov 11, 2012 | Hitachi 60EX01B 60" Rear Projection...
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
Color shadowing on white lettering
This is called convergence.
If the TV has auto convergence or 'Flash Focus', run it. All projection TVs have customer controls for minor adjustment. Give it a go with the menu or the remote convergence controls.
If not, this is a common adjustment made by a technician on a house call.
If the error is really big, say the colours are curved or you can see clear separate letters and things, you will need the convergence repaired. Get a quote - Usually about $300- $600 in home service.
Mar 29, 2010 | Televison & Video
RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rear Projection TV convergence
dear friend if you have that type of skills you cerlainly can either resolder or replace the convergence stks. you we'll need to replace both if that's the case. they look like the audio outputs in the audio amplifiers. good luck
caypianan@yahoo.com
Oct 12, 2008 | Televison & Video
3d image
This is what known as a convergence problem. First question is in your setup menu do you have a convergence option.. if you do then do you have any control in that mode does the crosshars move up and down and side to side... if you dont then you have a convergence power supply issue.. if you do it could be a setup issue. IF you do not have convergence in your setup menu then it possiblely be a special fuse.. and bad electrical connections. so let me know and ill see if we can narrow it down further
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ic chips
Hi did you check resistor protectors they are green pico fuses.
check your connections make sure all the wires are lined up with correct ones. I have done that lots of times.
In the menu you have to go to convergence and readjust the cross hatch each tv is a little differant to get to service menu you for adjustment..
keep me posted get me model number and i will get convergence code or the way to get into it for you .dont give up you will get it sometimes i go back to peoples houses a few times.
thanks doctor video.
May 13, 2008 | Panasonic PT-53WX53 53" Rear Projection...
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Jan 05, 2008 | RCA 32V420T 32" TV
Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Aug 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
