2003 Honda Pilot Logo
Posted on Jan 22, 2011
My radio code includes a zero while my prest numbers are 1 2 3 4 5 and 6. How do i enter the zero?
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 32 Answers
  • Posted on Jan 22, 2011
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
32
Questions
Helped
11929
Points
95
Refer to the vehicles user guide to ascertain hiden codes provided exclusively to the owner and operator of the vehicle. However, Usually computers that have only six number pads may have one of the button performing dual functions. For example, unless there were a menu button on the vehiclel stereo to control settings to acheive zero in place of one of the numbers, a press of on of the six numbers should produce a second funcion as zero figure. However, unless that the vehicle has been replaced with another stereo device still expecting the same features of only six number required from a new stereo having seven key functions. Inquir about the vehicles authentic stereo parts may have been replaced soon after acquisition from manufactuer.
3helpful
2answers
I have received the code for my radio but I can't find the number zero to enter the code. How do you get the number zero.
Hi Mozzsgroi, Better to ring a car dealer that sells your make/brand car and ask them your question.... I'm sure they would know Mate.... CHEERS..
Need radio code
Hold prest buttons #1 & #6 down, turn on radio. Keep holding down buttons, record 1st 4, then 2nd 4, of radio serial number. Either register your car on-line with Honda to get the code or go to a Honda dealer.
The radion does not work
Try this If its for a radio thats 2002 or older you will need the radio serial number in order to obtain the radio code. to do this you will turn the ignition on and the radio off. then push the 1 and 6 buttion at the same time. while holdting the buttons turn the radio on and u should show a code that begins with a U or a L. Write all numbers down. then contact the honda dealer for the code to your audio system. If you already have the code....do the following. Turn your ignition to ACC or on to power on thyour radio. Enter the radio anti-theft code using the prest buttons at the botton of your radio. For example, if your anti-theft code is 55512, "You would press the 5 button three times, then the 1 button, then the 2 button. this will unlock and rest your honda radio.
How do u set the code
If for a radio thats 2002 or older you will need the radio serial number in order to obtain the radio code. to do this you will turn the ignition on and the radio off. then push the 1 and 6 buttion at the same time. while holdting the buttons turn the radio on and u should show a code that begins with a U or a L. Write all numbers down. then contact the honda dealer for the code to your audio system. If you already have the code....do the following. Turn your ignition to ACC or on to power on thyour radio. Enter the radio anti-theft code using the prest buttons at the botton of your radio. For example, if your anti-theft code is 55512, "You would press the 5 button three times, then the 1 button, then the 2 button. this will unlock and rest your honda radio.
10helpful
2answers
Radio code for 2001 chevy blazer
1) Press the 2 & 3 numbers on your radio at the same time for about 10 seconds; a 3 digit code will come up 2) Press the am/fm button for about 10 seconds; another code will appear 3) Write those numbers down in that order 4) Dial 1-800-537-5140 and enter 202107 followed by the * sign 5) Enter the 6 digit code from your radio followed by an * 6) The phone number will give you a 3 or 4 digit override code, enter this code into your radio just as your owners manual tells you to NOTE, if the code you get back starts with a 0, drop the zero from the code. So if you get 0123, your code would be 123. Hope this helps out a lot of people and screws the dealers!
2helpful
2answers
I have a 1999 cabrio changed the battery now radio is asking for code I do not have the code what is my solution is there a default code i can try
Probably depends on the year/model of the VW. For a 1999 through 2002 Cabrio, you would need to do this: obtain the unlock code that was shipped with the vehicle. If you don't have the unlock code, your local dealership can pull the radio and look up the code with the serial number. Once you have the unlock code, then turn on the radio. You should see SAFE displayed. After about 3 secs, "0001" should appear. Use the station preset buttons 1 through 4. Preset 1 changes the first digit of the code, and preset 2 changes the second digit, etc. Enter all 4 digits of the code. After code is entered, press right side of "Seek" button for about 2 seconds, until an audible signal is heard. If you hose up and get the wrong code...will go back to SAFE displayed. You will get another chance to enter the code. After 2 failed attempts, you have to wait 1 hour again for it to unlock. So carefully enter the correct code the first time.
Volkswagen uses the radio lock feature to prevent unauthorized users of your audio system and will not allow your radio to operate without the proper unlock code.
Volkswagen began using the anti theft feature around 1990 and is still in use in most Volkswagen vehicles today!
Step 1 - Retrieve radio serial#
Your vehicle requires that you remove the radio from the vehicle in order to retrieve your radio's serial number.
Number will start with vwz.Must be a 14 digit number.You must include all numbers and letters included in the radio serial#, including "vwz". Radio serial# Found on chassis of vehicles radio. You must remove the radio from the vehicle in order to retrieve the radio serial number. This number may be stamped in the metal, on side of radio.
Step 2 - Retrieve vehicle V.I.N #Vehicle identification number.Usually found at the bottom of drivers side window.
Step 3 - Purchase code at
http://www.radio-code.com
  • You will receive your radio unlock code, via email.
  • Approximate code retrieval time is 30 minutes to 24 hours.
To do it yourself you will need to have the radio removal keys to unlock the radio compartment .
look at this site and you will have an idea :
http://forums.vwvortex.com/zerothread?id=967146
Radio code resetting
There is a four digit code for the radio, the previous owner will know it. Press two bottons at the same time and the display reads "0000". use the first four keys on the radio, that is "1", "2", "3","4" for each of the zeros and enter the code by pressing until the right number is displayed. Then press the same two bottons to enter this code and the radio comes out of safe mode..
7helpful
2answers
Need to input my radio code on 2005 Honda Civic
ok your radio displays ERR , OK 3 options let it sit for an hour turned on , to reture to CODE display , or pull the radio fuse out for a minute and put it back in , returning to the CODE display , or disconnect the battery for a minute , returning to the CODE display . you got the ERR display because the code was wrong or not entered correctly , make your choice of getting the radio back to the CODE display by 1 of those 3 choices , while the radio displays CODE , use the preset buttons , if the first number of your code is 4 , then press the #1 preset button 4 time , when the first number has been input , put the 2nd number in by pressing the #2 prest button , if 2nd number of code is 8 , press the # 2 preset button 8 times till the # 8 is displayed , and so on . you see where this is giong ? when you have entered all the numbers correctly you will have you radio back . when you say you have the radio code , good luck ! were rooting for ya .
J5
1helpful
Anti Theft Radio Code (Honda Odyssey 2004
You have the wrong stereo code. No Honda stereo code has a 0.Your local dealership parts dept. should be able to supply the stereo code given the VIN of the vehicle or serial number of the stereo.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
